broken dipstick tube in block - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 19th, 08, 11:11 AM Thread Starter
Bryan Hall
anyone have any bright ideas on how to get a dipstick tube that is broken off almost flush in my block.. been tryin everything to pull it out cant seem to get it..
My car pics...
dallas car show pics plus some of the cars i am building at work
importkiller69ss is offline
post #2 of 6 (permalink) Old Mar 19th, 08, 11:24 AM
Alan
Re: broken dipstick tube in block
What about one of those thingys from Sears for removing broken bolts?
http://www.bimmerboard.com/forums/posts/17946
I would change the oil afterwards just to make sure you got all the chips out.
alan
alanrw is offline
post #3 of 6 (permalink) Old Mar 19th, 08, 11:38 AM
I have heard guys inserting a lag bolt , get a good bite , then you can either spin it or pull it out. Use size needed for tube, I would guess a 1/4 or 5/16 bolt will grab the tube..
TC # 349
zdld17 is offline
post #4 of 6 (permalink) Old Mar 19th, 08, 11:49 AM
Harry
dawg's Avatar
EZ out should work fine
434 stroker
US Navy retired
dawg is offline
post #5 of 6 (permalink) Old Mar 19th, 08, 11:55 AM
Chad
Dont know if its a good idea or not, but I used a standard screwdriver (just big enough to be tight in tube) and got it to spin. Once it started spinning it came right out. What ever you use, the metal was real soft, so be careful.
67 RS "yes that is the factory color combo"
cgrady is offline
post #6 of 6 (permalink) Old Mar 19th, 08, 06:32 PM Thread Starter
Bryan Hall
ok ima try the easy out and or bolt i thoght about using a bolt but just wanted to check
My car pics...
