Tall Deck Question - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 19th, 08, 05:54 PM Thread Starter
Howie
Send a message via Yahoo to Howielones
Tall Deck Question
I was thinking out loud like I always do about tall decks, cranks, strokes, rods etc.
Let's say I have a piston with certain compression height designed for 4.250 crank and rod of 6.385...in very simple terms that is the equivalent of 10.635 crank/rod combo length---right/wrong?? So along those lines would a 4.00 crank and rod of 6.635 inches yield the same results if all other things were identical? I know 6.635 rods are rare and I am in no way saying I am doing this presently(maybe 12 months from now) but a 4.00 crank saves alot of machining to clear even a 4.250 in some instances (and more common). Again it was just my brain on boredom!
I am having a 496 built right now, and got hold of another virgin 4 bolt, siamese bore, tall deck standard bore, and original deck height. Why have only one project going when you can drive yourself insane with two?!
68 plain old stocker Maro. 350/350 LeMans Blue, Black insides...496 in the garage waiting
Howielones is offline
post #2 of 7 (permalink) Old Mar 19th, 08, 08:00 PM
Chris
Re: Tall Deck Question
Divide your rod length by your stroke length.
in my case: A 6.8" rod and a 3.74" stroke = 1.81:1 ratio.
68 Camaro, 555 big block, Doug Nash 5-speed, 3.54 gear.
smits67 is offline
post #3 of 7 (permalink) Old Mar 19th, 08, 08:46 PM
get long on the rods howie, long stroke stuff needs it, big strokers get the wrist pin placed so far up the pin bushing have to be cut for the oil ring. rods are cheap so get new ones.
prostock is offline
post #4 of 7 (permalink) Old Mar 20th, 08, 05:33 AM Thread Starter
Howie
I kept hearing that about longer rods for strokers prostock. Thanks for the input.
post #5 of 7 (permalink) Old Mar 20th, 08, 06:37 PM
1st off, tall deck BIG TRUCK 366 and 427 blocks are not siamesed! Only Bowtie and aftermarket block's!!
2nd, a tall deck block is .400" taller so use FOR A 496 in a tall deck block at least 1/4" longer rods and adjust piston compression height. And I figure .400" longer rods can be used too! Please run the numbers here to check for sure.
And you may want to look into the rods out of a Vortec 8100 BB b/c they are LONG due to it being a 4.25" b x 4.37" s = 496" tall deck w/ SB LS-type heads, BB stock engine!
pdq67
post #6 of 7 (permalink) Old Mar 21st, 08, 04:09 PM
you can put some more crank in that tall deck 427, i would put the 4.25 crank in a short deck , but u can go 4.5, 4.625, or 4.75 in the tall deck. bigger=happy borexborexstrokex .7854= cu in per hole x 8 holes=v8 bore it .100 to 4.35 go big
prostock is offline
post #7 of 7 (permalink) Old Mar 21st, 08, 05:14 PM
Smile Re: Tall Deck Question
Right, if you want to grind h-ll outta the lower end!
4.375" b x 4.60" s = 556.2"..
And this was done way back before the siamesed aftermarket blocks were around that we can NOW buy reasonably!!
My bet tho is on an aftemarket standard deck height block that's ...
4.56" b x 4.375" s = 571.6".............
OR taking her out to max at 4.625" to make a her 588".....................
He, He!! Stealth ALL the way..
pdq67
