turning BBC cranks - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 20th, 08, 02:04 PM Thread Starter
Keith
turning BBC cranks
How far can I safely turn a BBC crank, specifically a 427. They make bearings for .040 and .050 undersize for the rods, but can the crank handle that much of a cut wthout sacrificing too much strength? Thanks.
69X11 is offline
post #2 of 5 (permalink) Old Mar 20th, 08, 03:40 PM
Dante'
Re: turning BBC cranks
If I had to turn a crank more that .20 I would start looking for another crank.
69 Camaro SS
windycity1 is offline
post #3 of 5 (permalink) Old Mar 20th, 08, 05:57 PM
Bill
Keith,
The crank will handle any size that you can get bearings for. It is very common to offset grind the rods down to Small block size, thats .100" smaller ! Small block 400 cranks are turned down to 350 size every day to make 383's. Thats a .200" grind !! Most crankshafts are so over engineered that it is not a problem anyway.
What is more important than the size is having the crankshaft properly reground, especially keeping the proper radius on the journal ends.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 5 (permalink) Old Mar 20th, 08, 06:25 PM
I am almost positive you can buy .100" UNDERSIZE BB crank bearing sets, the suckers are THAT tough!!
And remember, the SB guys turn SB cranks down to Honda rod sizes that I want to say is 1.88" or so, but I may be off here!! I know they are SMALL dia.!!!!!!!
And they spin them upwards to 9,000 rpm!!
pdq67
post #5 of 5 (permalink) Old Mar 20th, 08, 06:49 PM
george
I think you meant .020".Typo??:BBC cranks have been ground to the honda 1.88 journal size.My machinist polished my old 427 crank that was ground .030/.030" with no concerns from him or myself.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
