fuel line? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 20th, 08, 05:11 PM Thread Starter
Big daddy
fuel line?
I'am replacing the fuel line with stock 3 piece z-28 line from classic,well when I tried to attach,I found that the linto the brass block is 3/8",bthe line to carb is 5/15" to small for the carb inlet.what going on? is this the wrong line?
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 4 (permalink) Old Mar 20th, 08, 06:29 PM
Re: fuel line?
Holleys are available with 2 different size inlet fittings. Yours are the larger 3/8 you need the 5/16 size to fit the stock type line. Inline tube or right stuff show them in there online catalog. I believe i have seen them in ricks and Ground up also.
Ryan
ssscamaro is offline
post #3 of 4 (permalink) Old Mar 20th, 08, 06:37 PM Thread Starter
Big daddy
Re: fuel line?
Ok,I see,but do you think that snakinging doon to 5/16 will hurt performance? were the all z-28 this way?
carhodge is offline
post #4 of 4 (permalink) Old Mar 20th, 08, 09:03 PM
SY1
Re: fuel line?
Yes they were that way. It won't hurt performance unless you're building a race car, for a street car it'll be fine. You can make your own lines and use your 3/8 Holley inlets if you want. Just buy a brass inverted flare tee fitting that has 3/8" fittings. That's what I do on my Holley carb engines and keep the 3/8" fittings on my carb.
"..............what, and get out of aviation??"
SY1 is offline
