quench/heat expansion... - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 20th, 08, 07:23 PM Thread Starter
AJ
Help me out... I'm trying to get as much compression out of a .040 327 with 58cc al heads, 4 valve relief stock type "eyebrows" as some call them i'm guessing their -7cc's??? Deck height measured at .014"-.015"
What is the smallest head gasket I can use with good quench and avoiding heat expansion to where my pistons wont hit the head??? I can get .013" gaskets.... Would those work or would I be making a costly mistake?
Thanks in Advance
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #2 of 3 (permalink) Old Mar 20th, 08, 07:34 PM
Re: quench/heat expansion...
I like to see about .035 -.040 quench, I think a GM .017 gasket would be the min. You are close on 7cc on those pistons, Maybe even 5 or 6 cc. Those 58cc chamber heads are gonna bump the compression up pretty high, about 10.5? Depending on your usage, I would lean towards the .028 gasket.
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Mar 20th, 08, 08:59 PM
SY1
Agree with Don here, .035-.040 with steel rods, need more with aluminum rods. Also need .080 intake valve to piston clearance, .100 exhaust valve to piston clearance as minimums. If you run a low perf engine you can run a little closer valve to piston clearance, but with w 327 you'll probably be winding it pretty high so I'd stick with the perf engine numbers above.
"..............what, and get out of aviation??"
SY1 is offline
