Headman Headers 65003 - Team Camaro Tech
post #1 of 16 (permalink) Old Mar 21st, 08, 07:18 AM Thread Starter
JcGc's Avatar
I'm getting to the point that I need to buy new headers. I'm looking at the Headman 65003 1 3/4 hearders for my 69 Camaro with a 408 SBC. Does anyone know if these will clear the power steering gear box?
Also Jet Hot has them listed at $463.00 for sterling coated. Is this a good price?
If anyone has any pictures of these installed could you post them up.....please!
Thanks for the help!
1969 Camaro
JcGc is offline
post #2 of 16 (permalink) Old Mar 21st, 08, 07:59 AM
Harry
dawg's Avatar
Re: Headman Headers 65003
I got the same set on my 406 (except ceramic coated) and it just barely makes it past my manual steering box.
ill post a pic today for ya
434 stroker
US Navy retired
dawg is offline
post #3 of 16 (permalink) Old Mar 21st, 08, 09:39 AM
Jerome
I have them 65003's Jet hot very nice I had to massage them past the manual box like Dawg....go to the Hedman site and pull up there parts list or call there Tech line ,I beleave they don't fit PS boxes ...Good luck Happy Motoring
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #4 of 16 (permalink) Old Mar 21st, 08, 10:57 AM Thread Starter
JcGc's Avatar
Well I tried calling headman today, but no one answered. Probably closed because it's good friday. I did however look at there web page and it say's the 65003 fits with power steering. I can live with dimpling the pipe to clear the gear box, if that is all I have to do.
Also will the headers fit with straight plugs?
1969 Camaro
JcGc is offline
post #5 of 16 (permalink) Old Mar 21st, 08, 11:13 AM
6D9
Ron
I had the 65003's on my 408 sbc 69. It has PS as well. Its a very tight fit but it did not rub. Maybe like a 1/16 or so clearence.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #6 of 16 (permalink) Old Mar 21st, 08, 11:23 AM Thread Starter
JcGc's Avatar
I can live with 1/16. Thanks for the info!!!!
1969 Camaro
JcGc is offline
post #7 of 16 (permalink) Old Mar 21st, 08, 01:40 PM
I have them on my 67. Had to tweek the tube to get clearance for the PS box. I also have energy motor mounts which will change the clearences a little. Great clearance under the car but be very careful not to try to flex the header under the car as it will cause the weld to break where it is welded to the flange. Been there done that!
67 Bassman is offline
post #8 of 16 (permalink) Old Mar 21st, 08, 02:28 PM Thread Starter
JcGc's Avatar
Which motor mounts are you running? I just purchased stock motor mounts, wonder if they will work.
1969 Camaro
JcGc is offline
post #9 of 16 (permalink) Old Mar 21st, 08, 03:21 PM
SY1
Had the 65003s on my 68 small block with manual steering and no clearance issues with the manual box. The idler arm will contact the right side header when turned to the limits. Other than that no issues. Can't help you on the jet coating, I order mine painted because I modify the primary tube flanges and refinish them and the coating would be destroyed in the process. I've always had good luck with VHT 1500 degree flame proof coating, that's what I'm using on the next set again next week.
"..............what, and get out of aviation??"
SY1 is offline
post #10 of 16 (permalink) Old Mar 21st, 08, 07:54 PM
Robert
They wouldn't clear my third gen ps box, looks the same as 1st gen box to me. Also it looks like they crammed 1 3/4 tubes into a 1 5/8 flange. The tubes actually look crimped at the flange. Seemed to defeat the purpose of the larger tubes. I understand this to be the case on the current version, older versions didn't have this odd configuration. I now use them on my test stand then back in the attic when done.
Robert
TC member #18
rojo is offline
post #11 of 16 (permalink) Old Mar 21st, 08, 08:21 PM
Joe
joe69rs's Avatar
Thumbs up Re: Headman Headers 65003
I have these headers installed in my small block car with all factory power steering equipment. It's close but they fit with no modifications. Good header for the price.
joe69rs is offline
post #12 of 16 (permalink) Old Mar 21st, 08, 08:34 PM
SY1
Robert I'd heard they'd changed the primary inlet design, but if it's changed as much as you claim then maybe I'd better look at something other than the 65003. My last pair were the old design. Maybe I'd be better off keeping the 1 5/8 set that came with the car, at least they fit the port.
SY1 is offline
post #13 of 16 (permalink) Old Mar 21st, 08, 08:49 PM
Robert
Hear say on my part about the old design, I've never owned a previous set. If they had cleared my ps box I would have used them. Still I didn't think the port size matched the tubes.
Robert
TC member #18
rojo is offline
post #14 of 16 (permalink) Old Mar 21st, 08, 09:02 PM
Robert
Here's a link where RickD had the same opinion of the ports. I bought my set with anticipation of needing a larger port but the ps box killed it anyway for me. I don't want to sound like I'm down on Headmans, just sharing my issues.
https://www.camaros.net/forums/showth...ighlight=65003
Robert
TC member #18
rojo is offline
post #15 of 16 (permalink) Old Mar 21st, 08, 11:20 PM
SY1
Thanks again Robert for the link. It's pretty disappointing for me hearing others also claiming the 65003 current design is necked down. I guess I'll start looking at my other options. Glad I came across this post, I was getting ready to order on Monday.
SY1 is offline
