rod bearing information - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 21st, 08, 08:12 AM Thread Starter
Freshing up a Vortec 5.7 L-31 motor.
It had a spun bearing on # 3 rod.
Crank will clean up with a turning,not sure how much it will take but it will go to the machine shop next week.
I have been looking at different types of rod and main bearings.
The question is in reference to Clevite 77 "h" bearings.
They say for med to high rpm engines.
Does this mean they will not work in a street engine that will see 2500 to 3500 for most of its life.
Does more money always mean better because they cost quite a bit more that other bearings available.
Thanks for the help
Chilli is offline
post #2 of 10 (permalink) Old Mar 21st, 08, 08:42 AM
Re: rod bearing information
The H series rod bearings have a larger chamfer on the end that is next to the crank fillet.
Many high end aftermarket cranks have a larger than nomal fillet radius to increase strenth. Unless your crank has "non standard" machining, you don't need H series bearings.
post #3 of 10 (permalink) Old Mar 21st, 08, 08:49 AM Thread Starter
a larger chamfer warrants that much more money??
Chilli is offline
post #4 of 10 (permalink) Old Mar 21st, 08, 11:06 AM
Tim
77wolf10.85's Avatar
An "H" bearing is also hardened in order to withstand higher power levels. A soft normal bearing will fatigue crack or pit when exposed to more force than design levels. At what level that occurs...?
An "H" bearing is not as forgiving in 1 aspect as a softer conventional bearing probably but that's just my opinion. Along with the hardness gained I would expect to lose some "embedability"(ease of taking a hit of crap without wadding up and siezing) because they aren't soft
Yes they are higher price. Are you getting price from Summit? They have decided to not have the normal "H" on their website and have the coated "H" instead. And it is very costly. You have to input the Clevite vendor# then the Clevite "H" # to get the regular H bearing. I think Jegs is the other way around and doesn't show the coated bearing unless you put in the part number. Coated is about 100 bux higher than hardened. Hardened is about triple regular if I remember right. soft25-hard75-coated175? ish. Just mains. 1 coated rod bearing costs about what a set of 8 regulars does. I know I bought rings and bearings to play with a 305 for less than a set of hardened mains. $72 bux to put new rings and bearings in a 305 with pretty holes, yeah sure wtf
Here's what coated H looks like. All my pics of regular H are worn from running lube free unintentionally. You lose a couple tenthou clearance with coated.
The H kinda looks like *** when new. The hardening process discolors them pitiful and you have the overwhelming desire to make Lurch noises when you look at them. The Tri Armour coated H is a beautiful bearing. The ugly brown fluid is EP-3 lube for threads.
Tim Smith
77wolf10.85 is offline
post #5 of 10 (permalink) Old Mar 21st, 08, 05:07 PM Thread Starter
77wolf10.85, was that motor for the street or strip?
Chilli is offline
post #6 of 10 (permalink) Old Mar 21st, 08, 07:28 PM
Tim
Strip, but it will still do some street.
Tim Smith
post #7 of 10 (permalink) Old Mar 21st, 08, 07:54 PM Thread Starter
would you use "H" bearings in a street motor?
Chilli is offline
post #8 of 10 (permalink) Old Mar 21st, 08, 07:59 PM
Tim
Not unless I was running a good forged crank.
Tim Smith
post #9 of 10 (permalink) Old Mar 21st, 08, 08:01 PM Thread Starter
thanks for the help, just a stock crank so I will run the standard softer bearing
Chilli is offline
post #10 of 10 (permalink) Old Mar 21st, 08, 08:03 PM
Tim
They do real good.
Tim Smith
