Motor mount help please, Thank You - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 21st, 08, 06:57 PM Thread Starter
On a 69 Z28 are the sub frame motor mount brackets the same height? Thats to say if you place both flat side down on a flat table would the holes for the long bolt be the same distance from the table. If one is different, which is it left (driver side) or right? Thank You
zgoat is offline
post #2 of 2 (permalink) Old Mar 21st, 08, 09:24 PM
Bobby
Re: Motor mount help please, Thank You
i have a set of 507 and 508 69 z28 brackets and the drivers side sits a 1/4" lower where the long bolts go thru. drivers side is 1 1/2" and the passenger 1 3/4"
69 Camaro Z/28 Rally Sport 10A of 68. 50 S with 723 int. .040 over 302 with m22 autogear wide ratio. BU 12 bolt posi.
69CamaroRT is offline
