Decked Block and Heads, now Intake leaks - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 21st, 08, 07:49 PM Thread Starter
Unhappy Decked Block and Heads, now Intake leaks
To anyone who can help,
I had a 327 engine and 194 camel hump heads decked for my 67 about 12 years ago. After s marriage and a couple of kids I finally got the car running again but it is blowing steam out of breathers and exhaust and oil film is present in the intake and heads. After pulling the intake to re-seal it a couple of times I gave up and pulled the heads to have them checked for cracks. No issue with heads but the shop noted that the intake gaskets that were still stuck to the heads showed signs of not pinching down properly and suggested continuing to work on that problem. So my questions: 1) With the decking, what head gasket/Intake gasket combination would you recommend? Go thick on head gaskets and standard on Intake gaskets.... Standard on head gaskets and switch to a different intake gasket thickness to compensate.... 2) Block is bored .030 over, just wondering what the bore diameter is for a 327. I need to order the gaskets from out of state and have them shipped to teh car so I can assemble when I get home. I am sure these are not difficult questions for many of you but I am at a loss and getting extremely tired of assembling and disassembling this engine. About to go the crate route.
biggytab is offline
post #2 of 5 (permalink) Old Mar 21st, 08, 07:55 PM
Tim
77wolf10.85's Avatar
Re: Decked Block and Heads, now Intake leaks
1. The intake may need milled. Bolt it up to one head only, with a gasket, then use a feeler gauge against the other head to see what you are dealing with.
2. 327 is 4.000 bore by 3 1/4 stroke. So you are 4.030
Tim Smith
77wolf10.85 is offline
post #3 of 5 (permalink) Old Mar 21st, 08, 08:34 PM
Joe A
I have 461 heads milled .0025 and my block was decked .030 on my 350 with an alum intake. The question I have to ask is... did you use the front and rear gaskets when you did the assembly ????
I was told not to because of the same problem you are going through. Run a bead of the black RTV sealent instead of the gaskets. You can see how my intake sits on the block and heads in my Sig Pictures without those gaskets.
1967 SS 350 Clone ( not hiding it )
Never Ending Project
camjoe63 is offline
post #4 of 5 (permalink) Old Mar 21st, 08, 09:29 PM
john
wagonman's Avatar
sealant is always better!!!!
the rubber end seals usually leak....
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #5 of 5 (permalink) Old Mar 23rd, 08, 06:29 PM
maybe the heads were cut before you got them, then u cut em, they could be cut .090 now. i have put on a felpro blue at .032 and a beaded steel at .017 stacked and used stock intake gaskets. use rtv on valley , sprayed the steel gskt with k&w copper spray and clean all gasket surfaces with solvent to get oil free, then use thin coat of rtv on intake gasket on both sides.
prostock is offline
