Hedman Husler Headers and A/C bracket location - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 24th, 08, 08:10 AM Thread Starter
I have installed a pair of Hedman Husler Hedders P/N 65003on my 67 Camaro with SBC and factory Air. I am looking for a diagram or picture of how the A/C bracket P/N 20110 is supposed to fit around the Hedder and plastic A/C evaporator box. I don't want to screw it up and lose by A/C. Any help would be greaty appreciated.
Thanks and Regards,
gearheadtx is offline
post #2 of 5 (permalink) Old Mar 24th, 08, 09:35 AM
Jerome
Re: Hedman Husler Headers and A/C bracket location
Well its all suppost to work, I am at the Hedman site now and F/N 26 is use bkt 20110 ,I have 65003's with out A/C so I am no help sorry ,I just though I would recheck for you ...Good Luck and Happy Motoring soon I hope for you
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #3 of 5 (permalink) Old Mar 24th, 08, 09:54 AM
Robert
The bracket is used to hold the rear of the compressor. Nothing to do with the AC box on the passenger side.
Robert
TC member #18
rojo is offline
post #4 of 5 (permalink) Old Mar 24th, 08, 08:19 PM Thread Starter
Hi,
Thank you for your reply. Which pipe does it go on from the back to front.
Thanks again,
post #5 of 5 (permalink) Old Mar 25th, 08, 05:56 AM
Robert
I have Hookers with a similar bracket, so I'm pretty sure to say it goes between cyl. #1 and #3 (the first and second tube). The slots go behind the header bolts (might need longer bolts) and the round hole connects to the rear of the compressor. The arched cut out between the two slots is to clear the temp. sending unit (if equipped) in the head. At first glance it appears that it would go over a tube so I think that's where some get confused.
Robert
TC member #18
rojo is offline
