Quick easy question... - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 25th, 08, 12:50 AM Thread Starter
Hey guys, I have a 1969 350 with a .030 overbore. I am looking for new head gaskets but the only gaskets that are 4.030 are for the LS1, on Summit's site. Am I looking for the wrong diameter bore? Any help is appreciated.
Jeff
edit: also, any recommendations on a good head gasket?
SepsiS is offline
post #2 of 6 (permalink) Old Mar 25th, 08, 01:41 PM
Re: Quick easy question...
FPP-1003 if you have cast iron heads and FPP-1010 if you have aluminum heads.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 6 (permalink) Old Mar 25th, 08, 05:25 PM
Bill
Jeff,
You are looking for the wrong bore size. Any gasket for the stock 350 bore size will fit all common oversizes like .030, .060 etc. The stock 350 gaskets will work.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is online now
post #4 of 6 (permalink) Old Mar 25th, 08, 05:33 PM
The gasket is always a little bigger than the cylinder.
post #5 of 6 (permalink) Old Mar 25th, 08, 07:57 PM Thread Starter
Thanks a lot guys, you've been very helpful.
I will post a work log when I start building. When I start, it will be a temporary build just to get it running again. I'm replacing only whats necessary for now and later down the road I will do a complete overhaul. Heres some pics of it as it was a few years ago.
It's a 1972 Camaro with a 69 block.
SepsiS is offline
post #6 of 6 (permalink) Old Mar 26th, 08, 05:25 PM
OK!
Gotta ask??????????
What brand main caps are those??
b/c they sure don't look STEEL colored like the crank, now do they! If that is a steel crank??
Or is it just a poor lit pic.?
pdq67
