327 to crate 350 damper - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 25th, 08, 10:13 AM Thread Starter
Hey guys, I think I've decided to go with a crate engine for my build. I'm going to make the crate engine look like the 327/275 L30 set up, and I've already got a bunch of the parts.
My concern is the vibration damper. I don't have one of them yet, so I'll need to get one. GM offers part #12551537 as a damper for their crate engine, and it's called a "clearance problem" damper. It is 6 3/4" diameter, 2 3/8" total "thickness" (snout and all) and the snout only is roughly 1 1/8" of it.
Does anyone have a confirmed original 327/275 damper they could look at and maybe measure, give me the part # on it, and possibly verify for me this GM damper will work as a replacement? Has anyone ever used one of these smaller GM dampers on a crate? Would I be better off trying to find an original 327/275 damper and use it?
I'm concerned about the new GM damper messing with my pulley alignment on everything else I've got for the build. Thanks in advance, Brian
'68 RS Vert
68vert is offline
post #2 of 2 (permalink) Old Mar 25th, 08, 11:47 AM
Re: 327 to crate 350 damper
If you used an original 327 dampner it would most likely be for a short water-pump set up. I am not sure if they changed the thickness of them, when they went to the 8" balancer or not.
TJS69 is offline
