engine choice - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 25th, 08, 06:38 PM Thread Starter
engine choice
im lookin to put a new engine in my 69 camaro but i only have about
$4000...what engine could i get that has a lot of horse power???
need4speed9 is offline
post #2 of 8 (permalink) Old Mar 25th, 08, 06:39 PM
Eloy
Re: engine choice
Edelbrock 350 Crate Engine Has a Lot Of Horsepower and is Very Reliable
Bowtie707 is offline
post #3 of 8 (permalink) Old Mar 26th, 08, 06:10 AM
Kyle
Re: engine choice
Here is a set up for you from T & L engines .. New style aluminum heads by Dart ... this is the engine I'm looking at... good hp good tq good price...
383 Aluminum A-3 440 HP 465 Torque - $3988
Scat 3.750 crank
• Scat 6.000 bushed rod
• S/P hypereutectic pistons
• Moly file fit ring
• GM 4 bolt block
• Dura-bond cam bearing
• New block plug kit
• Oil filter adapter
• T&L custom hydraulic roller cam
• Roller timing set
• Custom gasket set
• Chrome timing cover
• Professional products balancer
• Balancer bolt
• Timing pointer
• Melling high volume oil pump
• Melling drive shaft
• Melling oil pump pickup
• Hydraulic roller lifter
• Dart or RHS aluminum heads
• 7/16 screw in rocker stud
• Comp cam push rod
• Aluminum roller rocker arm
• Edelbrock RPM Air Gap manifold
• Chrome V/C
• Chrome oil pan
• Autolite spark plugs
• Oil filter
• Fuel pump plate
• 12pt bolt kit
Labor
• All parts hand cleaned
• Block sonic checked for thickness
• Block pressure tested @40 psi
• Block stroker clearanced
• Block square decked w/BHJ fixturing
• Aligned hone mains
• Bored and honed w/torque plates
• All clearances checked to the nearest .0001”
• Rotating assembly balanced
• Engine blueprinted w/specs sheet on file
• Engine fully assembled and dressed to customer specifications
• Dyno tested
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #4 of 8 (permalink) Old Mar 26th, 08, 05:09 PM
Re: engine choice
I bet you can create a homemade 550hp/496 BB for under $4,000, but it will cost some MORE to install it, only b/c it's a BB swap!
Springs, rad., s/b, both frame and rubber mounts, etc....
I did!
pdq67
post #5 of 8 (permalink) Old Mar 28th, 08, 10:25 AM
Re: engine choice
Scat 3.750 crank
Moly file fit ring
GM 4 bolt block
New block plug kit
Oil filter adapter
Roller timing set
Custom gasket set
Chrome timing cover
Balancer bolt
Timing pointer
Melling drive shaft
Comp cam push rod
Chrome V/C
Chrome oil pan
Oil filter
Fuel pump plate
12pt bolt kit
Labor
Aligned hone mains
Dyno tested
Where is this place located? That seems like a pretty good price. Has anyone had any experience with this place?
deerhunter is offline
post #6 of 8 (permalink) Old Mar 28th, 08, 11:48 AM
Jerome
Re: engine choice
Call and talk to Scott at Gilbert Chevrolet 1-800-545-0048,He's got plenty of combo's very good guy..Happy motoring
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #7 of 8 (permalink) Old Mar 28th, 08, 12:01 PM
Kyle
Re: engine choice
12303 Renee Ford Rd, Stanfield, NC 28163
Phone 704-888-8111 Fax 704-888-8114
I have heard many positive things about this company!
http://www.tandlengines.com/
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4:11 POSI
post #8 of 8 (permalink) Old Mar 28th, 08, 12:48 PM
Re: engine choice
I would stay away from them. I have an uncle who purchased one of there 408SBC's and has had some issues with what he ordered and what he actually received. First they were 6 weeks late on the motor and then we finally called they said it will ship that day. It didn't! He called back two weeks later and they said it was on the dyno and will ship the next day. Two weeks later he called again they said they were just crating it up.
This leads to this week. He gets the motor two weeks ago and some of the parts are different then what he ordered. Like a Petronix dist. instead of the MSD the paperwork says and a few other things.
Needless to say he and myself have called for two weeks now and only get an answering machine and no return phone calls.
He is gpoing to Myrtle Beach golfing next week and is making a surprise visit.
I would stay away!!!.
Erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi.
Erik Beckett is offline
