Quiet gear drive - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 25th, 08, 10:45 PM Thread Starter
Quiet gear drive
Hello all
I have a OE style factory roller cammed motor and want to run a gear drive I see you can only buy a quiet gear drive for this style motor but I wanna hear the whine.
My question is does any one run a gear drive on a factory roller cam motor and if so what gear drive and is it noisey??
David_H is offline
post #2 of 9 (permalink) Old Mar 25th, 08, 11:08 PM
Brandon
Re: Quiet gear drive
This is the one I have in mine http://store.summitracing.com/partde...0&autoview=sku
You can barely hear it until about 3k rpm, then it almost sounds like a blower.
I was told the reason it is quiet is the single idler gear. if you want a loud one get a pete jackson.
mine is not a factory roller, but it is a 350 with a solid roller cam
Hope this helps
Pix of my cars...
brandonc707 is offline
post #3 of 9 (permalink) Old Mar 25th, 08, 11:15 PM Thread Starter
Thanks for the reply
I need a noisey one to hide valve train noise between 1500-2000 rpms I am told its normal for my setup but it makes me crazy so I figure I would install a gear drive( I like the whine) but the pete Jackson drive says it only comes in a quiet gear drive for my year and style motor...
If any one is running the P.J quiet drive I would love to know if it is really quiet..
David_H is offline
post #4 of 9 (permalink) Old Mar 25th, 08, 11:27 PM
Brandon
http://store.summitracing.com/partde...1&autoview=sku
Here is the one that fits your application. in the description is says "noisy" I havent heard this one.
Call Summit, there tech guys are usually pretty good
Pix of my cars...
post #5 of 9 (permalink) Old Mar 26th, 08, 05:28 AM
Patrick
I run a quiet Pete Jackson and it is not that quiet. Still has that "whine" to it. I can also hear my valve train as I run a solid flat tappet. I like to hear my engine to know if something is wrong rather than the loud whine of the noisy gear drive.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #6 of 9 (permalink) Old Mar 26th, 08, 05:33 AM
Doug
DougP's Avatar
I ran one of the "noisy" Pete Jackson gear drives, and eventually got rid of it. It worked fine and sounded pretty good, but after a while the novelty wore off and I decided to go back to a regular timing chain setup.
==Doug
Former
owner
Former
owner
Former 2nd
owner (
DougP is offline
post #7 of 9 (permalink) Old Mar 26th, 08, 05:55 AM
What's wrong with a little valve train noise? On my road racer it was the signature noise of the motor.
onovakind67 is offline
post #8 of 9 (permalink) Old Mar 26th, 08, 04:22 PM Thread Starter
I just don't remember engines sounding this way pissed off sewing machine
thanks
David_H is offline
post #9 of 9 (permalink) Old Mar 26th, 08, 04:29 PM Thread Starter
Will do thanks
I don't mind hearing the engine I just don't like the clatter of lifters etc. I am thinking of pulling the cam rockers etc and replacing with stock
I found this set up for my oe style roller cam anyone use this brand?
http://www.cloyes.com/HighPerformanc...S/Default.aspx
David_H is offline
