my new engines first test run - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 26th, 08, 01:37 PM Thread Starter
Harry
dawg's Avatar
Ok after setting the timing which is running happy at 38 degrees total and adjusting the 4 corner idle (highest vacum was 16")
and fixed the timing pointer scaping the balancer.
I took her for her first run
stabbed the pedal and spun the tires!
I also found out the tranny isnt going in to first gear?
did a longer run to check the kickdown and it needs adjustment.
once i took it back I noticed smoke (tranny oil)
I put in a chrome tranny dipstick (el cheapo spectre) and its pukin out all over the place where the dipstck tube enters the tranny.
any fixes for this or should i buy a lokar tranny dipstick?
guess I got a few wrinkles to iron out.
oh the seal on the distributor weeps a bit of oil too.
434 stroker
US Navy retired
dawg is offline
post #2 of 9 (permalink) Old Mar 26th, 08, 02:00 PM
luke
Re: my new engines first test run
i had the same problem with the spectre dipstick. i took the o-ring off and scuffed the polished metal so RTV would stick to it and rtv'd mine. haven't seen a drop out of mine in the 2 months since i did it.
lukeciffer is offline
post #3 of 9 (permalink) Old Mar 26th, 08, 02:10 PM Thread Starter
Harry
dawg's Avatar
yeah serves me right for buying the cheap stuff.
still trying to think how i lost first gear though?
but engine runs GREAT!
434 stroker
US Navy retired
dawg is offline
post #4 of 9 (permalink) Old Mar 26th, 08, 02:11 PM
Kevin
SixtyAte's Avatar
Normal...blowby pressure. Are you running a PCV ? Once rings seat it should stop. See what others say...
Kev
SixtyAte is offline
post #5 of 9 (permalink) Old Mar 26th, 08, 02:42 PM Thread Starter
Harry
dawg's Avatar
just a slight weep
I got a PCV and a breather.
oil pressure is at 50 to 60 psi
434 stroker
US Navy retired
dawg is offline
post #6 of 9 (permalink) Old Mar 26th, 08, 04:51 PM
Timothy
Where is the video? At least a picture or audio clip. Scratch and sniff?
My 69 RS/SS 396 Project -
"I may be dumb but I aint stupid"
Microgiant is offline
post #7 of 9 (permalink) Old Mar 26th, 08, 05:53 PM Thread Starter
Harry
dawg's Avatar
its comin as soon as i get the kinks worked out
434 stroker
US Navy retired
dawg is offline
post #8 of 9 (permalink) Old Mar 27th, 08, 05:04 AM
Kyle
as far as your dipstick tube is concerned .. i have used a form of locktite (green i believe) that is used to hold bushings in place (we used it on real big earthmoving equipment) i bet if you scuffed up the chrome and used that stuff on the dipstick tube i bet that stuff would stop any leaking!
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #9 of 9 (permalink) Old Mar 27th, 08, 05:31 PM Thread Starter
Harry
dawg's Avatar
ok dipstick tube leak fixed!
(sanded the chrome off the sealing surface)
no leaks and dry as a bone.
oil leak from fuel pump (changed pump to a holley )
edelbrock pumps suck!)
now to deal with the no first gear problem (shifter linkage TH350)
434 stroker
US Navy retired
dawg is offline
