462 casting - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 27th, 08, 11:28 AM Thread Starter
Trevor
462 casting
I have a set of 462 casting heads and would like to know how to tell how much has been taken off of the surface to determine the CC's of the heads?
osin68 is offline
post #2 of 3 (permalink) Old Mar 27th, 08, 11:42 AM
jim
Re: 462 casting
Average milling for Darts are.005" BB -.0065" SB per cc. Probably similar chamber shape. I WOULD SAY ITS VERY SIMILAR. Average it out
67 RS Deluxe Int. A/C car
TKO-600
400 4 bolt block .03 over
Ported 215 Pro1 Platinums
Forged/balanced 400 crank, pistons, 6" rods
286HR cam w/1.6 rckrs LS1 beehives
Forgelines, 18"f 19"r, 4 link w/ minitub
IROC s/gear, 4 wheel discs
quickboat is offline
post #3 of 3 (permalink) Old Mar 27th, 08, 11:45 AM
Vintage 68's Avatar
Wink Re: 462 casting
Stock head surface is @1.408(+/- .005)" from the center-line of the intake bolt hole to the head surface - but this is tough to measure correctly due to angles being 10deg. off ...
It would be easier to just CC one of the chambers and use the number.
Stock chamber should be @63 (+/- 1)CC's.
1968 Convertible
Some trucks
Vintage 68 is offline
