DCR and octane - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 27th, 08, 07:06 PM Thread Starter
DCR and octane
Is 100 octane enough?
My info.
Cam http://www.compcams.com/Technical/Se...umber=12-771-8
Bore 4.060"
Stroke 3.75"
Disp 388ci
Pistons -5cc
DITH 0.015
gasket bore 4.166
thickness 0.039 (yeah i know my quench is too big)
victor jr heads 64cc
First of all, did i do the calc right?
Second, will 100 octane be good for me? I have a good source that can get it at his cost, but he can't get the higher octane stuff at the low price.
Thoughts?
67Builder is offline
post #2 of 7 (permalink) Old Mar 27th, 08, 07:16 PM
Re: DCR and octane
I got exactly the same numbers using PatK's calc.
Are you sure you can't find a set of 70-72cc heads, or some d-dish pistons?
Or maybe a lil bigger cam even?
That's a lot of compression.
post #3 of 7 (permalink) Old Mar 27th, 08, 07:30 PM Thread Starter
Re: DCR and octane
I can go bigger on the cam.
Could go bigger heads, but there's more money in that.
Pretty unwilling to change pistons.
The car is really going to be an occasional street driver, but mainly track time is what i see it doing.
How much will going with a bigger cam help me?
Using this cam http://www.compcams.com/Technical/Se...umber=12-704-8 will get my DCR down to 8.088 What kind of octane would i be looking at there?
post #4 of 7 (permalink) Old Mar 28th, 08, 07:39 AM
Trevor
Talking Re: DCR and octane
Hay Brian where did you get that calculator from?
osin68 is offline
post #5 of 7 (permalink) Old Mar 28th, 08, 08:20 AM
mbrekke's Avatar
Re: DCR and octane
Try plugging your values into this:
http://www.bid2race.com/DynamicCompr...Calculator.php
When you click 'calculate' it gives you a minimum octane for that comp. ratio.
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
post #6 of 7 (permalink) Old Mar 28th, 08, 03:39 PM Thread Starter
Re: DCR and octane
http://www.kb-silvolite.com/calc.php?action=comp
That's where i got that calc from.
with this cam http://www.compcams.com/Technical/Se...umber=12-705-8
my DCR goes down to 8.816.
That should be low enough for even the crap gas you get from the station.
But is the 100 octane enough to run this thing with a normal amount of timing as it sits today? I've got it started up on 93 octane running retarded and rich. Don't want to push it too hard till i get some better gas in the tank though.
post #7 of 7 (permalink) Old Mar 28th, 08, 05:00 PM
Re: DCR and octane
I use this one for DCR.
http://www.rbracing-rsr.com/comprAdvHD.htm
and this one for SCR.
http://www.campbellenterprises.com/R...alculators.htm
pdq67
