starter fitting question - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 28th, 08, 03:31 PM Thread Starter
i did the paperclip trick with the starter to make sure the clearance was ok, everything was fine there. BUT the starter is sticking on the flywheel. If it is shimmed or not. could it be that the flywheel is to far over and needs to be loosened and adjusted?.....HELP!!!!
68 Camaro RS/SS, 454 BBC,TH400,
Atth2o is offline
post #2 of 4 (permalink) Old Mar 28th, 08, 04:59 PM
ralph
Re: starter fitting question
try one thin shim on the motor side of start an make sure you have a bracket from start to block flywheel is non adjustable
west 68 is offline
post #3 of 4 (permalink) Old Mar 28th, 08, 05:04 PM Thread Starter
its a mini hi-torque there is no braqcket that i am aware of...is there?
man this new engine swap is killing me..lol
Atth2o is offline
post #4 of 4 (permalink) Old Mar 28th, 08, 05:51 PM Thread Starter
i just looked at something and this is what i found. On the old mini-starter I had that worked (before it fried) the throw out gear was shorter than the one on the new mini starter. So apparently this is the problem with it catching up. Are big block mini starters and small block mini starters the same? Or is this common and I have the incorrect starter?
Atth2o is offline
