No spark again - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 28th, 08, 09:32 PM Thread Starter
Bob
MileHigh69's Avatar
No spark again
A month or so ago I posted a problem I was having with my ignition. I traced it down to the resistance wire causing enough voltage drop to keep from generating enough voltage to create a spark. I ran a new wire from a switched source on the fuse box and it fixed the problem. Well here it is about 1 month later and it doesn't seem to have a good spark. I have a new Billet HEI distributor in it and it was running fine. I ran a hot wire from the batt directly to the dist cap but it only had 11.26 volts. I need to charge the battery then will try again tomorrow. Could it be a insufficient ground? Any other ideas?
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #2 of 4 (permalink) Old Mar 29th, 08, 10:00 AM Thread Starter
Bob
MileHigh69's Avatar
Re: No spark again
I had a new ignition switch laying around and decided I would try this. I installed it and charged the battery and it sparks and starts now. Perhaps the ignition switch was wearing and causing a voltage drop on the line. We will see. Now on to the next problem.
post #3 of 4 (permalink) Old Mar 29th, 08, 10:11 AM
Alan
Re: No spark again
Or the battery was too low.
alan
alanrw is offline
post #4 of 4 (permalink) Old Mar 29th, 08, 02:21 PM
Re: No spark again
I lost all power (no spark, cranked great) coming home from the track at 10:30pm ish. No flashlight, but lucky to have a buddy following... bad ground cable... all new cables (+ & -) and a few extra ground wires for GP ... no more issues
68 Camaro~LSx ~all motor
