Pulley HELP!!! - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 29th, 08, 11:32 AM Thread Starter
Bill
Send a message via Yahoo to IDS_Bill
Pulley HELP!!!
Okay so I got my crank pulley that we narrowed it down to (remember these would be for a 396/375 w/PS w/o smog) and I tried to install it and the water pump pulley and the crank pulley overlap about 1/8". I got the 3906656 pulley that is supposed to be corect for the motor and the 3869978 crank pulley but I can't figure out why they don't fit. The water pump pulley is 7 1/8" diameter and the crank is 6 3/4.
I need help guys - any ideas?
Bill
67 Yenko Tribute - 427/4SPD/Bolero Red
2010 2SS/RS Camaro - Victory Red with White Rally Stripes
IDS_Bill is offline
post #2 of 8 (permalink) Old Mar 29th, 08, 12:07 PM
Fred
Re: Pulley HELP!!!
I just measured as close as I could. (My original 396-375hp pulleys are installed) (also they are for non power steering and WITH A.I.R.) The water pump is close to, or a little less than 6". The crank pulley (two grove) is right at 7", near as I can tell.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 8 (permalink) Old Mar 29th, 08, 12:38 PM Thread Starter
Bill
Re: Pulley HELP!!!
Thanks Fred - I am totally confused on this one...
IDS_Bill is offline
post #4 of 8 (permalink) Old Mar 29th, 08, 01:08 PM
Smile Re: Pulley HELP!!!
I have seen where the hub on the water pump was not pressed on in the correct location causing the pulleys not to line up. There are shims available to shim out the water pump pulley. You may have to add shims or see if the hub can be pressed on farther. You may want to get a measurement from the face of the hub to somehere on the pump and compare to another pump.
TJS69 is online now
post #5 of 8 (permalink) Old Mar 29th, 08, 02:07 PM
Re: Pulley HELP!!!
If he's got a 7" water pump pulley and Fred has a 6", then he has the wrong water pump pulley.
post #6 of 8 (permalink) Old Mar 29th, 08, 02:34 PM Thread Starter
Bill
Re: Pulley HELP!!!
That's what I am thinking. It has the correct parts number on it but there is no freakin' way this thing would fit.
IDS_Bill is offline
post #7 of 8 (permalink) Old Mar 29th, 08, 03:03 PM
Fwiw, my '67's single belt 350SS pulleys are on my 496!
And I bought a crank P/S pulley and didn't need to unknowingly b/c I now have p/s.
The 327 that was in my car when I got it back had my 350SS's pulleys on it and a crank p/s pulley and I'd forgot about it b/c it's been years is all.
pdq67
post #8 of 8 (permalink) Old May 9th, 08, 07:17 AM
Wes
Re: Pulley HELP!!!
IDS_Bill I had exactly the same thing happen to me on my 67 396/325. I can't remember the sizes but they overlapped and didn't fit. I grabbed my waterpump pulley from my 67 Truck with a 283 and it fit I think it was a 6" pulley. But their is not enough room between the two to get the belts on. Their is about 1/8" clearance and the crank pulley sits back behind the waterpump pulley about an 1/8". I am trying to add PS and get everything lined up. It is frustrating trying to get all of the pulleys lined up and working.
TorqueRules is offline
