does this sound like a good set up? - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 29th, 08, 01:44 PM Thread Starter
AJ
4.040X3.25 327 (really 333)
190cc Aluminum heads, 58cc chambers, 2.02/1.60 valves, flow 263 @ .500
4 valve relief flat top pistons
.014" deck height
.013" steel shim head gasket
Comp Cams 286/286 adv duration .490" lift 110lsa
1.5 ratio Stainless Steel full roller rockers
Weiand Team-G single plane intake (will this even fit under a stock flat hood??)
1-5/8" long tubes 3" collectors
3.08 rear gear (willing to change)
4-speed
45,000 volt Pertronix ignition system
750 edelbrock, yes I know its too big....
This car is NOT a daily driver, a weekend car for the street that will be taken to the track when ever I feel like it...
Let me know what you think. I cannot change the heads or rockers since they are already in my garage so please don't post your .02 saying to change those parts, that is what i have to work with, the intake, cam is not ordered yet.
Lemme know what you think...
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #2 of 2 (permalink) Old Mar 29th, 08, 03:29 PM
Re: does this sound like a good set up?
Probably at 10.94 to 1 CR. so you should be fine, cam-wise, imho..
And if the Team G is the same height as a Holley 300-36, I think it will fit.
BUT please check me here??
pdq67
