How to tell if it's hydraulic or mechanical cam? - Team Camaro Tech
post #1 of 22 (permalink) Old Mar 29th, 08, 05:13 PM Thread Starter
Jeff
Back on the old project, 1969 block, 1.94 heads, 383 motor. Compression was all over the place 140 to 185 pounds. Intake roller rockers are 1.5's, exhaust are 1.65 (not sure why though). Anyway, assuming it was a roller hydraulic cam as the previous owner said, we reset all the valves today. Taking each cylinder to TDC one at a time, we took both sides to zero lash and gave it 1/4 turn more. It didn't fire and so I checked 1 and 3 real quick = no compression now. Maybe solid lift after all?
I suppose that means I just screwed up, but without taking everything apart, how can I tell what the lash should be set at? It's a Comp Cam setup, but we have no specs at all. Suggestions?
I hate being stupid, but it didn't run anyway so I really haven't lost that much ground...lol.
-shoe
Current Projects - See my albums
68 Coupe Restomod (7-2010 to ???)
67 RS/SS Convertible project (8-2007 to ???)
Old
67 SS 396 Coupe (sold 7-12), 68 SS 350 (sold 2-12), 68 383 stroker (sold 10-09), 68 SS 350 TPI (sold 2006), 69 SS 350 (sold 1987), 68 327 (1980 Bench seat column shift), 89 RS (son totaled), 88 IROC (son totaled), 76 LT1 (roommate wrecked)
shoe is offline
post #2 of 22 (permalink) Old Mar 29th, 08, 09:06 PM
Re: How to tell if it's hydraulic or mechanical cam?
You would sure think that it wouldn't be a solid roller for the street! Those things usually have some sick lift.
dubs68camaro is offline
post #3 of 22 (permalink) Old Mar 29th, 08, 10:40 PM
Smile Re: How to tell if it's hydraulic or mechanical cam?
Solids will hold the valves open when lashed too tight so it won't run at all right! Hy's- will bleed down OK then pump back up so will still run OK, at least until you can lash it warm like it need's to be done, imho.
And if you lash hy's- too far, they turn into solids and will do like them until loosened back up so that they can pump back up and turn back into hy's-.
It's best to lash both using the old "spin the p/r between the thumb and index finger" so you know it's at zero lash on the base circle and then go from there! Cold first at start-up, then lash hot idling like it need's!!
I always lash both hy's- and solids idling hot, BUT it was how I was taught as pup by the old Mechanics around town AND it is a "feelie" deal!!
Hy's, back them off until they tick, then a 1/4 to a 1/2 a turn down! Solids, use the needed feeler gauges and "feel" them as you lash! In and out w/ the gauges idling! And put a clean shop towel over the other 1/2 of the valvetrain that you aren't adjusting to help hold oil splash to a min.
pdq67
post #4 of 22 (permalink) Old Mar 29th, 08, 10:58 PM Thread Starter
Jeff
More opinions on roller cam and lash?
Growing up I was taught to go 3/4 to 1 full turn on standard hydraulics, but never had a full roller motor. My neighbor is telling me to just snug it up to zero lash and stop there.
I played around with it a little more, did do the push rod spin trick, but once all the play is gone and I go 1/4 turn, its all over with the compression.
Extra note: When I first started into this, I noticed that at TDC, all the exhausts (1.65's) had a little gap to them, but the intakes (1.5's) were all tight. Not much, but tight. I just figured the 1.65's had backed off just a little. Starting to wonder now if they are solid and I missed the point.
-shoe
Old
shoe is offline
post #5 of 22 (permalink) Old Mar 29th, 08, 11:20 PM
I bet it is a solid cam.
Lash it at .020" on the intakes and .022" on the exhausts cold and see what it does? Should turn into about .024" and .026" hot???
pdq67
post #6 of 22 (permalink) Old Mar 30th, 08, 10:15 AM
Ron
A Solid Lifter whether it is Flat Tappet or Roller does not Pump Up. You can not push down on the cup to bleed off the tappet like a hydraulic one.
With a small Mechanical Roller with lifts around .600" the COLD Tappet Clearance is approx .022" for Int and Ext. Pending whether the cam is asymmetric. That is same lobe design for both Int and Ext. If the cam is not asymmetric that is say a higher lift and longer duration on the Ext you usually add .002" to the Ext. Of course the bigger the Mechanical Cam the Bigger the Clearances. It would be a good idea to pull the Timing Cover and read core ID from the End of the Cam and get the Spec Sheet for it.
Setting Tappets at TDC is NOT a good Idea because you are not on the smallest radius on the Cam's Heel and you can easily get mixed up were the Engine indicates TDC for a particular Cylinder; such that, the Cam is on Over lap were both the Intake and Exhaust Valves are supposed to be open. A good example is comparing #1 and # 6 Cylinders were #1 is firing under compression with both Valves closed at TDC but #6 is on Overlap "savaging" with both valves partially open at the TDC indication for that cylinder.
This is how I Set Tappets whether the Cam is Hydraulic or Solid - Following the Firing Order for that CAM: Be aware that some cams have different firing orders.
1st slacken off all Tappet Adjusters to ensure you do not kiss a piston with a valve during the procedure.
Starting with #1 Cylinder adjust the Exhaust Tappet such that the lifter is riding on the lowest portion of the lobe heel with the recommended Spec's of say .022".
Intake Valve: When the exhaust valve begins to open, stop and adjust that cylinder's intake valve.
Exhaust Valve: After the intake valve has been adjusted, continue to rotate the engine, watching that same intake valve. The intake valve will go to full lift and then begin to close. When the intake is almost closed, stop and adjust the exhaust valve on that particular cylinder
You will rotate the engine several times by hand with the spark plugs out before you are satisfied the adjustments are right on. Move the feeler gauge side to side and do not roll it under the Rocker Rollers.
This was my 70 1/2 Z28
Z15CAM is offline
post #7 of 22 (permalink) Old Mar 30th, 08, 10:23 AM Thread Starter
Jeff
Thanks I will try that this afternoon if it stops raining. The previous owner did some nice work on this car, then totally whack things the next moment (like welding the leaf springs to the rear end). Seems like they put some money into the motor, but may have been a 1/2 way job in the end.
What the main reason for a solid lift roller cam as opposed to hydraulic, is it a racing thing or just preference?
-shoe
Old
shoe is offline
post #8 of 22 (permalink) Old Mar 30th, 08, 10:29 AM
Ron
You can Rev a Mechanical Cam much higher then a Hydraulic Cam simply because it is Mechanical using higher Spring Pressures and does not depend on Hydraulics to pump up.
I highly suggest you pull off the timing Cover a see exactly what you have there and get the Spec sheet for the cam. Hopefully the info will be engraved on the front and not the back of the cam in which case you will have to pull the cam itself.
Z15CAM is offline
post #9 of 22 (permalink) Old Mar 30th, 08, 12:39 PM
Tim
77wolf10.85's Avatar
I would just look down into the top of a lifter to see if there is a keeper or not.
No little clippy keeper = solid
Tim Smith
77wolf10.85 is offline
post #10 of 22 (permalink) Old Mar 30th, 08, 01:09 PM
Good point Tim!
pdq67
post #11 of 22 (permalink) Old Mar 30th, 08, 03:18 PM
What I was about to say, Sometimes you can see a wide flat bi-metal looking snap ring too. Sorta concave looking.
TC # 349
zdld17 is offline
post #12 of 22 (permalink) Old Mar 30th, 08, 03:27 PM
george
fwiw..my piddle valve style solid lifters have a snap ring inserted above the cup.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #13 of 22 (permalink) Old Mar 30th, 08, 05:17 PM
Ron
A keeper or snap ring does not necessarily identify whether the lifter is Hydraulic or Solid; as fatblock mentions. Often the same core is used to make either a Solid or Hydraulic lifter. Piddle Valves do not compress but direct pressurized oil from the lifter galleries up the push rod to lubricate the push rod ends and Rockers. Harley Riders often convert a Hydraulic Roller to a Solid Roller lifter.
I take it the car is new to you. Why don't you talk to the previous owner or mechanic to get information on the engine?
Z15CAM is offline
post #14 of 22 (permalink) Old Mar 31st, 08, 10:57 AM
If you back off a rocker, let it set for a bit, then tighten the rocker to 0 lash, then slowly tighten the rocker, does it push the pushrod down more or is it solid? You might need a dial indicator for this. I don't remember how much 'spring' a hydraulic lifter has but solids have 0. I think I wrote this clear, maybe not, but I tried.
deerhunter is offline
post #15 of 22 (permalink) Old Mar 31st, 08, 04:03 PM
Ron
I understood what your saying a believe a dial indicator would determine if the lifter is one or the other. I would suspect the Hydraulic to have somewhere between a .060" to .100" travel. I agree the Hydraulic travel is hard to detect by hand.
Z15CAM is offline
