Tap extractor ? - Team Camaro Tech
post #1 of 21 (permalink) Old Mar 29th, 08, 07:16 PM Thread Starter
Dave C
Tap extractor ?
I like an idiot use a tap with a 3'8 air ratchet an broke it in the head for the headers. Has anyone used a tap extractor with success? Thanks in addvance.....
PRO.ST69orange
post #2 of 21 (permalink) Old Mar 29th, 08, 07:19 PM
Tim
77wolf10.85's Avatar
Re: Tap extractor ?
Yes they work. Snap On is all I have used but I imagine others make them too...
Tim Smith
77wolf10.85 is offline
post #3 of 21 (permalink) Old Mar 30th, 08, 08:39 AM Thread Starter
Dave C
Re: Tap extractor ?
Thank You this gives me a little hope...
PRO.ST69orange
post #4 of 21 (permalink) Old Mar 30th, 08, 03:21 PM
Re: Tap extractor ?
Tap is hard stuff, very brittle. Last one I got out , I had to almost burn it out, made a mess and install helicoil. The head was off.
TC # 349
zdld17 is offline
post #5 of 21 (permalink) Old Mar 30th, 08, 05:46 PM
Re: Tap extractor ?
LOL...Flashback of my boss shaking in anger and telling me to get lost while he repaired my mistake.
Just be careful when "extracting" it, you can end up breaking the extractor or otherwise messing it up worse.
When it begins to bind, it's time to back up. Fluid is a must. Sometimes you may have to heat the surrouding metal. Hopefully with a couple squirts of penetrating fluid and a careful rocking motion will free it up and let it back out all the way. BTW: What you want to prevent is thread gawling - that's probably what caused it to break off in the first place. Little bits of metal get between the tap and the thread grove jamming up the works. Rocking back and forth should break off the cuttings and loosen up again.
dnult is offline
post #6 of 21 (permalink) Old Mar 30th, 08, 07:26 PM
Re: Tap extractor ?
I sheared my crank pulley bolts off of mt blower motor. My buddy used left handed drill bit and they came right out. He did say it was hard to find the bits! good luck.
jd502 is offline
post #7 of 21 (permalink) Old Mar 31st, 08, 04:40 AM
Tim
Re: Tap extractor ?
Guys, he's not after a bolt he's after a sheared off tap. You can't drill a tap. A tap extractor has 4 long male flutes that match the female flutes of a tap.
http://cgi.ebay.com/ebaymotors/Walto...em200210801047
http://www.waltontools.com/products/extractr.htm
they even show using it on a head
Tim Smith
post #8 of 21 (permalink) Old Mar 31st, 08, 03:06 PM
Cisco
battleax's Avatar
Re: Tap extractor ?
You can try a hammer and punch. Gently tapping it counterclockwise until you can grab it with a needlenose pliers or needlenose vicegrips. Taps are hard and brittle so like Tim said you can't drill it out. In a pinch you can hit it with a hammer and punch until it breaks and take it out in pieces, the head is out of the car, right? Good Luck
1969 Convertible ZZ4/350 Hotchkis TVS West Coast Diff
battleax is offline
post #9 of 21 (permalink) Old Mar 31st, 08, 03:15 PM Thread Starter
Dave C
Re: Tap extractor ?
No the head is on the car I hope the tap extractor from MSC works my buddy said we would get it....
PRO.ST69orange
post #10 of 21 (permalink) Old Mar 31st, 08, 05:47 PM
Bob
Re: Tap extractor ?
You can't use an air ratchet with a tap. You have to work it, in back it up, work it in more and back it up a little. If you just keep going you bind them up.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #11 of 21 (permalink) Old Mar 31st, 08, 06:19 PM
Re: Tap extractor ?
If/when you get the broken tap out of the head you may find that your going to to have to move up in thread/bolt size. By using that tap in an air ratchet I bet the tap acted almost like a drill bit removing the metal you wanted to make threads in.
Glacier Blue/Dover White 69 SB SS Restoclone.
99 Trans Am...my toy
Old Man is offline
post #12 of 21 (permalink) Old Mar 31st, 08, 06:24 PM
Andrew
Andrew69's Avatar
Re: Tap extractor ?
I have used the 2 and 4 finger tap extractors before and sometimes they do work. I would think they might work better in the cast iron, so that's in your favor. If you can get it to work back and forth just a little you might that that thing out of there. Use plenty of compressed air on it to get most of the chips and dust out of there.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #13 of 21 (permalink) Old Mar 31st, 08, 07:56 PM
Tim
Re: Tap extractor ?
That's what I was taught, and then one day about 20 years ago I was having a bigass air intercooler for a big ugly 7000"³ V-12 resealed at a radiator shop in New Iberia Louisiana... walked in the door and a kid was running an impact with a 3/8NC tap in all the holes." 'eek' said I...wtf and whuffo you riskin my intercooler so casual like eh?!!" The child calmy replied "awww we don't break too many off and if we do we just weld a nut on em and take em out". Sheesh
Then one day about 15 years ago, the first time they sent my big dumb Okie *** up to Milwaukee where they make those ugly engines... we are cruisin thru their factory and at the end of the crank line I see this bigass rotatin head pop out with 3 drills and a second later there's 3 holes in the end of the crank.... it rotates out of the way and another gizmo with 3 bigass taps cuts threads in about under a minute I reckon .... and I'm going Sheesh these Yankees and Cajuns got biguns eh? Now I know the factory taps were on a power driver...NOT an impact.... and also the taps are sooper dooper stuff....NOT what you and I own. But I thought ' ya know fatboy let's give that **** a try'. And I did, and it works. For chasing threads, I never tried to cut threads. And I won't do it with less than a 1/2" tap and only when/where I won't get screwed too bad if it breaks. Never broke one with an impact. Hell guys, some of the junk I work on I may decide to chase a couple hundred sets of threads on a job if it's junky enough. And these old shoulders got better stuff to hurt for than runnin a stinkin tap. Of course you still have to go in and out with an impact same as by hand. Just use your ears and you can feel it too. Got to have an impact you can tickle, some flavors are hard as hell to feather the trigger.
Tim Smith
post #14 of 21 (permalink) Old Apr 2nd, 08, 05:43 AM Thread Starter
Dave C
Re: Tap extractor ?
Yeah I know all the things I should do but some times ya get stupid and tired and all that stuff but anyway the tap extractor worked and worked well. I'm so happy the car is off my [email protected] list its my friend again I don't want to sell it, burn it, or blow it up.Now I can get back to progressing.......
PRO.ST69orange
post #15 of 21 (permalink) Old Apr 2nd, 08, 07:27 AM
Hank
Re: Tap extractor ?
When tapping cast iron,you do not use any oil or tapping fluid for tapping.
MBHD
Chevy 250 turbo EFI
mean buzzen half dozen is offline
