AFR 195 Eliminators and small pop ups? - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 30th, 08, 03:30 PM Thread Starter
Has anyone used the AFR 195 Eliminators with the older style L79 pop up piston that is only like a small 1/8 inch dome. with a 65 cc head it should be around 10.5:1 compression with the full out formula. Ill include a pictre of the piston. Its not a big dome at all. I just didnt know with the new designed chambers if there might be an issue. Right now with double humps that have been shaved down to about 62 cc I have no issues at all with them. I am looking to update my heads with a bigger cam also. Thanks for any info or advice!
This is the link to the picture. http://i48.photobucket.com/albums/f2...2166nf30_w.jpg
66chevyiiss327 is offline
post #2 of 2 (permalink) Old Mar 31st, 08, 07:36 AM
mbrekke's Avatar
Re: AFR 195 Eliminators and small pop ups?
Give the AFR people a call. They should be able to tell you right off the bat.
I have the same pistons and did a head swap (not AFR) to the newer chamber design with no problems. If they are actual Vortec style chambers they may not work though.
Edit:
Here's what the chamber looks like on the heads I just put on.
http://www.dartheads.com/products/he...s-s-heads.html
Here's a Vortec chamber.
http://www.chevymania.com/tech/vortec.htm
The 'point' on the quench surface extends farther into the chamber and may interfere with the dome.
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
