Will a Mallory HEI Distributor Fit? - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 30th, 08, 06:05 PM Thread Starter
Steven
I bought a Mallory HEI distributor for my small block (which is out of the car) and it looks too big.
Will the HEI fit in a original engine bay?
1968 Rally Sport
Corvette Bronze, 327, M-20 4 Spd
PW, PB, AC, Deluxe Int, Vigilite
Norcoastal is offline
post #2 of 8 (permalink) Old Mar 30th, 08, 06:12 PM
Re: Will a Mallory HEI Distributor Fit?
coil in cap hei's will fit in some, but most need some firewall "adjustment" to get them in there. You don't know for sure until you try.
post #3 of 8 (permalink) Old Mar 30th, 08, 06:16 PM Thread Starter
Steven
Got it, pull out the fine tuning tool
1968 Rally Sport
post #4 of 8 (permalink) Old Mar 30th, 08, 06:20 PM
AJ
If it does not and you know your transmission mount to the cross member is old replace it and it could get you just enough clearance, worked for me.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 8 (permalink) Old Mar 30th, 08, 07:36 PM Thread Starter
Steven
Good suggestion, thanks
1968 Rally Sport
post #6 of 8 (permalink) Old Mar 30th, 08, 08:13 PM
I have a Mallory HEI on my big block and it fits just fine. It is a tight fit, but it should work for you. Seems some cars are different though. My friend has a 69 with a small block and he had to do a little firewall adjustment. Good luck.
67camaroguy is offline
post #7 of 8 (permalink) Old Mar 30th, 08, 09:11 PM
if you have 302 or 350 mounts, then, no it won't clear.
if you have 307 or 327 mounts, then, yes it will clear.
you don't plan sincerity.
novaderrik is offline
post #8 of 8 (permalink) Old Mar 31st, 08, 10:42 AM
New body mount rubbers will help some too. My HEI in a 350 is close but I didn't need to hammer anything. It also was a 327 originally.
deerhunter is offline
