Would someone please recommend a decent fuel pressure guage? - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 30th, 08, 07:16 PM Thread Starter
Greg
I installed a crossram manifold and the Y has a place for a fuel pressure guage. I had an old mechanical one around but the needle bounces and shakes worse than grandpa. Somebody recommend a decent (not terribly expensive) one, and maybe where to get it? Thanks as always gents.....
greg1ontheedge is offline
post #2 of 9 (permalink) Old Mar 30th, 08, 07:58 PM
Re: Would someone please recommend a decent fuel pressure guage?
well, until I got to the "not real expensive" part...
I've got an autometer electric in my dash, it works great.
post #3 of 9 (permalink) Old Mar 30th, 08, 08:04 PM Thread Starter
Greg
Thanks for taking time to reply Jim, I appreciate that. Yeah, I can put a plug in the Y and somebody would know the difference. I just thought a decent guage that didn't jump like it's bein electrocuted to look kinda nice :-) Yeah, don't want to spend more than maybe $30???? Need one just screws into the Y, not electric or nothin. Thanks again.....
post #4 of 9 (permalink) Old Mar 30th, 08, 08:09 PM
If you don't care where the guage is Summit has a liquid filled gauge that works just fine. Just my two cents
67camaroguy is offline
post #5 of 9 (permalink) Old Mar 30th, 08, 09:37 PM
Bob
MileHigh69's Avatar
Try this one from Jegs.
http://www.jegs.com/p/JEGS/763500/10002/-1/10339
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #6 of 9 (permalink) Old Mar 31st, 08, 07:19 AM Thread Starter
Greg
Gents, thank you. I read through many forum threads and every question is answered, every need is met. Unreal. Thanks again..........
post #7 of 9 (permalink) Old Mar 31st, 08, 10:22 AM
Eric
The only one I have had any luck with is the Auto Meter. And yes, I tried the rest of them. If you are running a mechanical fuel pump without a pressure regulator, the needle is going to bounce. If you want a steady needle you have to run a regulator.
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #8 of 9 (permalink) Old Mar 31st, 08, 10:40 AM Thread Starter
Greg
Thank you Eric. I don't use a regulator and hadn't considered adding one. I'd heard (not reliable source) that a liquid filled guage wouldn't bounce like the mechanical one I have. It doesn't reaslly bounce, more like vibrates very very fast, like between 5-8 lbs. It's not cool at all. I may just put a decent looking plug in the Y-bloack, although I really like the guage idea. Thanks again sir.........
post #9 of 9 (permalink) Old Mar 31st, 08, 12:52 PM
Eric
The needle movement is actually the pulse of the pump diaphram, and I agree, I like the look of the pressure gauge.
ERIC
ept000 is offline
