Correct Centerforce flywheel? - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 30th, 08, 09:32 PM Thread Starter
The Centerforce flywheel part #700170 is stated as being the one to use with a ZZ4 or ZZ383 GMPP crate motor. I got one for my ZZ383. I am surprised that this flywheel has no balance weight on it. I see holes drilled in it in one area around the perimeter. I was expecting to see an added weight.
Did I received the wrong part?. I see no markings or stickers indicating the part number 700170.
There is a Centerforce logo sticker and a small white stick with the number F097527. There are numbers engraved just below the white sticker "097527 07-08
Can anyone using this flywheel shed some light on this for me?
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 6 (permalink) Old Mar 31st, 08, 03:29 PM Thread Starter
Re: Correct Centerforce flywheel?
Btt
__________
post #3 of 6 (permalink) Old Mar 31st, 08, 03:53 PM
ZZ_430's Avatar
Fred, I show that is the correct flywheel. When they drill 23.4 ounces out of the perimeter in the right place, it's like adding the weight to the opposite area.
I always use the 15lb GMPP flywheel, so I've never used the Centerforce. I see it's twice as heavy. I can get away with a lighter flywheel due to a 3.26 first gear in the Richmond trans I have always used with it.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 6 (permalink) Old Apr 1st, 08, 06:14 AM
Jerome
Fred I am doing the same thing and got a ZZ4 short block afr heads ,TKO600 from Classic Motorsports I will check the number and manf. of the flywheel and post tomorrow
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #5 of 6 (permalink) Old Apr 1st, 08, 06:37 AM Thread Starter
I called Centerforce yesterday and got the straight scoop. It is the correct one.
__________
post #6 of 6 (permalink) Old Apr 2nd, 08, 06:07 AM
Jerome
OOP's sorry Fred ,as I get older I forget and have to write things down ,sound's like you got the scoop ...Happy motoring
