Team-G and stock flat hood - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 31st, 08, 08:35 AM Thread Starter
AJ
Will a Weiand Team G fit under a stock flat hood on a 68' camaro small block. Edelbrock carb will be used along with what ever air filter will fit.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #2 of 2 (permalink) Old Mar 31st, 08, 09:07 AM
Kevin
Re: Team-G and stock flat hood
Can't say 100% for sure, but I have a '68 RS that originally came with a 327. I replaced the 327 with a 350 using the same engine stands and had a Team G (that I need to sell by the way) with a Holley 650 or 700. I can't remember, but I still have the carb, so if you know of a way to check, or want a measurement, let me know.
But, I had the SS style hood, the one with the inserts in the top, and NOT the flat hood. I did use a 4" or better air filter element too, but don't have that to measure anymore. So, if you know the difference between the flat hood and the SS hood, this might give you some information.
-Kevin
'68 RS Camaro, 454 SBC
'69 Camaro, body only
MissionCritical is offline
