please help me identify this type of holley fuel bowl - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 31st, 08, 01:42 PM Thread Starter
I think these came on some muscle cars but I can't be sure. Does anyone know what this type of Holley this came off of, and were they single or double pumpers? Also, was this a primary or secondary bowl? Thanks!
dubs68camaro is offline
post #2 of 6 (permalink) Old Mar 31st, 08, 01:51 PM
DjD
DjD's Avatar
Re: please help me identify this type of holley fuel bowl
List 4346 (780cfm vac sec) has a vent on the primary bowl like that. It was used on 370hp 350's, 375hp 396's and 425hp 427's in '69 per the '69 Chassis Service Manual
...Dennis
DjD is offline
post #3 of 6 (permalink) Old Mar 31st, 08, 04:48 PM
Eric
As Dennis said, the 4346 uses that style of primary bowl, as do several other GM factory carbs (3246, 3247, 3613, 4492, 4557, etc.)
Ford also used the same style of bowl on some of their carbs as well; does it have a single threaded fuel inlet just on the left side (as you view it from the front), or are both sides drilled & tapped?
Eric
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
post #4 of 6 (permalink) Old Apr 1st, 08, 08:17 AM
Early OEM type carbs. The smog gods made them change to a closed system so the bowl vent went away.
oger is offline
post #5 of 6 (permalink) Old Apr 2nd, 08, 07:25 AM Thread Starter
Eric
Boff sides are treaded!!!!
post #6 of 6 (permalink) Old Apr 2nd, 08, 07:31 AM
Eric
That would be a Ford bowl then.
Eric
