Loose Rocker Arm - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 31st, 08, 01:52 PM Thread Starter
Loose Rocker Arm
Any ideas to to why after a 50 mile run one of my rocker arms (intake) came loose? On my small block car, the rocker arm came loose after a 25 mile drive with the engine running at a constant 3000-3500 RPM.
This is not the first time this has occurred. I have had to re-adjust this same rocker several times now over the past few weeks. The adjusment is further down the the rocker stud than on the other valves. I'm afraid I might be experiencing cam lobe going flat.
The motor came with the car and has a very lopey idle 10hg or so due to the cam. So far, it has about 2200 miles on it. 1500 by me. The problem starting about 3 weeks ago.
Any help/ideas would be appreciated. I'm not opposed to pulling the cam but I just got the car running great after a Edelbrock RPM Air-gap 2*4 installation and was hoping to putt around until I get a new BB installed this summer.
Larry
69 Camaro Sallee Chev. 630hp/502, Martz sub-frame, Tremec, Moser 12 bolt.
2nd 69 Camaro Soon to be a Lewis Racing 540ci Motor currently being built.
C5 Corvette
2004 MDX
2001 Honda Accord
1999 GMC Truck
LarryC5 is offline
post #2 of 9 (permalink) Old Mar 31st, 08, 02:05 PM
Skip
Skeeter55's Avatar
Re: Loose Rocker Arm
Well if you have hydraulic lifter, you could have just a calapsed lifter ( Bad lifter )..Hopefully not a bent push rod..
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 9 (permalink) Old Mar 31st, 08, 02:08 PM
mbrekke's Avatar
Are they pressed in rocker studs? It may be pulling the stud out.
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
post #4 of 9 (permalink) Old Mar 31st, 08, 02:16 PM
Skip
Skeeter55's Avatar
Check to see if the rocker has a cracked down the middle of it...
Check the ball under the rocker and make sure its evan there (goes over the stud then the rocker)..
post #5 of 9 (permalink) Old Mar 31st, 08, 02:20 PM
Banned
Ron
Badbird's Avatar
The rocker arm nuts have worn threads.....Poly locks will cure this prob.
Badbird is offline
post #6 of 9 (permalink) Old Mar 31st, 08, 02:30 PM
If that nut is further down the stud threads than all the others, I doubt it's just a nut working loose on it's own.
It could be a stud pulling out tho.
The first thing I'd do is measure and compare the lift on that valve to one of the others.
If you don't have a dial indicator, you can just use a small machinists rule, measure from the head surface to the retainer. Hopefully you get the same measurement on that valve and a good one.
post #7 of 9 (permalink) Old Mar 31st, 08, 02:40 PM
ZZ_430's Avatar
Larry, long time no see.
It sounds like you're losing that cam lobe.
Jim's suggestion about measuring lift is a good idea.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #8 of 9 (permalink) Old Mar 31st, 08, 04:08 PM
Ron
If you don't notice something obvious like a very loose fitting Rocker nut or split Rocker Arm , I would test the lobe profile using a Dial Indicator and compare to another.
This was my 70 1/2 Z28
Z15CAM is offline
post #9 of 9 (permalink) Old Mar 31st, 08, 09:18 PM Thread Starter
To Everyone:
Thanks for the input. The ideas are great starting points for me to investigate. At this stage, I may be running into a cam lobe going south. The rocker arm looked OK and no bent push rod. I did have a tick-tick sound every now and then upon start-up after week or so sitting.
BTW: The heads are late model GM Fastburns w/screw-in rocker studs.
I may check the lift on of cam with a dial indicator but it is not looking too promising. This is a total bummer if the cam is bad.
I will fill everyone in on the final diagnosis just as soon as I can get to the car this coming weekend.
Regards,
Larry
C5 Corvette
2004 MDX
2001 Honda Accord
1999 GMC Truck
LarryC5 is offline
