70 engine in a 69 camaro - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 31st, 08, 09:59 PM Thread Starter
Since I'm not interested in matching numbers as far as the motor, what is the downside of getting a 69 SS with motor from a 1970... value wise or mechanically
okiemark is offline
post #2 of 10 (permalink) Old Mar 31st, 08, 10:04 PM
Re: 70 engine in a 69 camaro
If the engine is not original to the car, it will NEVER be numbers matching. You may get period correct, but NEVER numbers matching. Oh... now you change it to not interested.
TJS69 is offline
post #3 of 10 (permalink) Old Apr 1st, 08, 07:28 AM Thread Starter
yes, as I stated, I'm not interested in a numbers matching motor. So, I know putting a 70 motor in a 69 car makes it "Not matching". I'm an Okie, but give me some credit!
okiemark is offline
post #4 of 10 (permalink) Old Apr 1st, 08, 04:36 PM
It should be the same engine spec-wise, imho!
B/c GM didn't drop the CR. until '71!
pdq67
post #5 of 10 (permalink) Old Apr 1st, 08, 05:14 PM
Banned
Alan
98blackburb's Avatar
Have fun with it, I have a 69 SS with a 97 Vortec 420 HP. I'm having more fun with that a "matching #'s"....if you're into that fine but at most car shows people say nice car and that's it......just have fun
98blackburb is offline
post #6 of 10 (permalink) Old Apr 1st, 08, 10:37 PM Thread Starter
I've learnd that it is a 350 "4 bolt" that is in there now. he doesn't know where it came from. how do I know if the specs match before I go further?
okiemark is offline
post #7 of 10 (permalink) Old Apr 1st, 08, 11:41 PM
Get the casting numbers from the block, heads, crank, cam, carb and intake manifold and that ought to about tell you what you have. FYI, my 69 SS restoclone has a 70 Vette 350 CID 300 HP motor in it and I don't care what it came out of it's not original to the car but I can tell you it's fun.
Glacier Blue/Dover White 69 SB SS Restoclone.
99 Trans Am...my toy
Old Man is offline
post #8 of 10 (permalink) Old Apr 2nd, 08, 06:00 PM
Post back the letters at the end of the VIN number string that should be on the deck pad that's right above the pass. side,top water pump bolt so we can decode what it started out life as if it's not still a virgin.
pdq67
post #9 of 10 (permalink) Old Apr 5th, 08, 08:56 AM Thread Starter
I have learned that it is a "4 bolt" 350... as I stated, I'm not concerned it's not the original matching motor. But, does it decrease the value even further if it's not even from a camaro? (not "correct")? if so, how much
okiemark is offline
post #10 of 10 (permalink) Old Apr 5th, 08, 10:40 AM
Imho, no!
Again, please post back the VIN LETTER'S so we can decode it.
pdq67
