Camshaft options, opinins needed. - Team Camaro Tech
post #1 of 17 (permalink) Old Apr 2nd, 08, 12:32 PM Thread Starter
I have a 1969 350 with a .030 overbore and I going to rebuild it soon. When I got the car, the cam was a Comp Cams Magnum 292H. 292/292 501/501
After a few months, I started losing power and I couldn't get the timing right so I pulled the motor and started disassembling it and found 2 lobes rounded off of the cam.
I've been reading some bad things about Comp Cams and the lobe issues so I want to ask you guys what cam manufacturer I should go for instead of Comp. I'd like something with the same qualities/specs or close to them. I loved the lopey idle and it made great power but I don't trust Comp anymore.
I've been looking at Crane, Lunati and Trickflow but I don't know what I should go for. I'm pretty new to engine building so any help is appreciated.
Here are the original cam specs. http://store.summitracing.com/partde...3&autoview=sku
Thanks guys, Jeff.
SepsiS is offline
post #2 of 17 (permalink) Old Apr 2nd, 08, 01:11 PM
jim
Re: Camshaft options, opinins needed.
Cam selection is completely dependent on the rest of your setup. Including converter stall, rear gear and driving preference. There are many threads already here to choose from so do some reading and if you still have questions we’ll tackle it then.
67 RS Deluxe Int. A/C car
TKO-600
400 4 bolt block .03 over
Ported 215 Pro1 Platinums
Forged/balanced 400 crank, pistons, 6" rods
286HR cam w/1.6 rckrs LS1 beehives
Forgelines, 18"f 19"r, 4 link w/ minitub
IROC s/gear, 4 wheel discs
quickboat is offline
post #3 of 17 (permalink) Old Apr 2nd, 08, 01:30 PM
Banned
Ron
Badbird's Avatar
Stay away from the regrinds!....That's most likely what caused your 2 rounded lobes....You can't go wrong with a nice new Lunati cam!
Badbird is offline
post #4 of 17 (permalink) Old Apr 2nd, 08, 01:33 PM
Robert
If your car was okay with the 292H I can recommend the Lunati VooDoo 60104. A little less duration with a little more lift. Nice lopey idle and revs quick.
Advertised Duration IN/EX: 276/284
Duration @ .050 IN/EX: 233/241
Gross Valve Lift IN/EX: .504"/.525"
LSA / ICL: 110/106
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 2200-6400
Robert
TC member #18
rojo is offline
post #5 of 17 (permalink) Old Apr 2nd, 08, 06:05 PM
Chris
The world of flat tappet cams has changed.. . .with the OEM's going hyd roller or overhead valve core quality has dropped along with lifter quality and origin of mfg. Take this and add the EPA has made oil companies take out all the anti wear additives in oil a flat tappet cam for the future is not a good idea. I am told by some respected people in the industry that the life of a flat tappet cam nowdays is around 15 to 20K miles before it goes flat.
I would recommend hyd or solid roller.
Chris
cstraub is offline
post #6 of 17 (permalink) Old Apr 2nd, 08, 06:31 PM
Tim
77wolf10.85's Avatar
Chris, what have you heard about the nitride hardening Comp is offering? anything?
Tim Smith
77wolf10.85 is offline
post #7 of 17 (permalink) Old Apr 2nd, 08, 10:52 PM Thread Starter
I'd like to go for a hyroller but 1k for cam and lifters is just out of my price range.
I've read most of the cam threads on here and have gotten some good ideas. Currently my car has a 2500 stall in a th350 and a 10 bolt with 4.56 gears. I'd like to go with 4.11's though later down the road.
I'll have to check out the Lunati. Thanks guys and keep the suggestions coming.
SepsiS is offline
post #8 of 17 (permalink) Old Apr 3rd, 08, 07:31 AM
Chris
Tim,
Doesn't matter if the lifter doesn't have proper crown or the cam lobe doesn't have taper. If the lifter doesn't spin it just peels the lobe off.
Chris
cstraub is offline
post #9 of 17 (permalink) Old Apr 3rd, 08, 07:34 AM
Chris
I understand but let me give you another way to look at it.
Flat tappet cam and lifters $200
Intstall time $0 to $200
breakin oil/filter $30
Total $230 to 430
IF the cam fails, double the above then add up bearings, gaskets, and labor to pull engine appart to clean and install new bearings. That $1000 for the hyd roller may put you ahead of the game...
Chris
cstraub is offline
post #10 of 17 (permalink) Old Apr 3rd, 08, 11:08 AM Thread Starter
Thats a good way of looking at it Chris.
Which roller would you suggest? Would the Comp Thumpr be good? Or should I expect just another ****ty comp cam?
Also, for roller cams, the lift is usually higher, so what should I be looking for as far as specs if I used the 292H and it was perfect?
Sorry for all the questions, I'm a newbie.
SepsiS is offline
post #11 of 17 (permalink) Old Apr 3rd, 08, 02:50 PM
Buy some CHEAP "SF" grade oil from Walmart if you can find it and then add half a small bottle of EOS or whatever they call it nowadays and go!
And I always put moly lube on the lobes, the lifter feet, p/r ends and rocker balls and change my oil and filter after it's broken in and repeat the cheap oil and EOS along w/ a new filter.
pdq67
post #12 of 17 (permalink) Old Apr 3rd, 08, 03:27 PM
Greg
Total $230 to 430
I couldn't agree more. All it took was one lobe wiped to convince me.
68 383, TH-350, 3.55 Eaton Posi, Holley SA 770, RPM Air Gap, World Sportsman II, ISKY Roller Cam
emperor91108 is offline
post #13 of 17 (permalink) Old Apr 3rd, 08, 03:34 PM
Chris
pdq67
Paul,
All that doesn't matter. Look I love flat tappets. For a period of time I ground more SBC flat tappets then anything and then came '02 and the lifter issues. Also you don't Detroit using flat tappet cams anymore so core suppliers are not held to the PPM defective rate of the last 50 years. Lube will do nothing for you if the lifter can't rotate.
Chris
cstraub is offline
post #14 of 17 (permalink) Old Apr 3rd, 08, 05:52 PM
Chris,
What keep's them from rotating if I make darn sure and hand spin them in their bores when I assemble it and I use the lube and oil and break the cam in right like I've always done?
Are you saying the cores you have to use nowadays suck so therefore you shouldn't be selling flat-tappet cams ground on them??
pdq67
post #15 of 17 (permalink) Old Apr 3rd, 08, 05:59 PM
Chris
Chris,
pdq67
The lobe has to have taper and the tappet has to have crown. If the lobe is flat, straight across, and/or the lifter is flat, no crown then the lifter will not rotate in the bore.
Are there cam cores coming from China, you bet. It is junk.
Chris
cstraub is offline
