Motor mount headache, too much info? - Team Camaro Tech
post #1 of 12 (permalink) Old Apr 3rd, 08, 10:30 PM Thread Starter
Ok, I have just finished reading most of the posts regarding motor mounts and frame mounts and all the differences. ( Including the one from Pozzi's ) My head hurts. I'm more confused than when I started.
I'm pulling the original 350 out and replacing it with a ZZ383. This change involves going from a 6 3/4 inch damper to a 8 inch damper. It appears that after taking a few measurements that the 8 inch damper will hit the sway bar.
My '69 is a 01D production so I don't know if that is early or late for a '69. It is an L65 350 it was originally a 350TH automatic.
I've decided that I need motor mounts that are narrow and measure 2 3/8 from hole to plate.
What should the measurement be for the frame stands, hole to subframe?
I'm hoping that I just need new motor mounts(or slightly thicker mounts)
Got any Excedrin handy?
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 12 (permalink) Old Apr 4th, 08, 03:59 AM
Re: Motor mount headache, too much info?
just use the same mounts as before, and shim the sway bar down with some washers.
if you have the original 350 mounts, then an 8" balancer should clear just fine- those are the same mounts that were used for the 302, and that had the 8" balancer on it.
you don't plan sincerity.
novaderrik is offline
post #3 of 12 (permalink) Old Apr 4th, 08, 04:46 AM
Eight-inch balancer required a 'dropped' swaybar about the balancer. As derrick suggests, space the swaybar down to clear the h/balancer.
post #4 of 12 (permalink) Old Apr 4th, 08, 10:02 AM
How much clearance do you need? 1/4"? Solid steel spacers between block and rubber mount, if you have the clearance. I would use the smaller balancer.
TC # 349
zdld17 is offline
post #5 of 12 (permalink) Old Apr 4th, 08, 01:58 PM
Smile Re: Motor mount headache, too much info?
As everyone has said, use all your original mounts (frame and motor). You allready have the correct frame mounts. Shim your swaybar down for clearance. They used that small swaybar for stock. Use the 8" balancer. There is a reason that they went to the larger balancer.
TJS69 is offline
post #6 of 12 (permalink) Old Apr 4th, 08, 02:57 PM Thread Starter
Looks like I will just get new replacement mounts and do some shimming on the sway bar.
Thanks for the good responses,
__________
post #7 of 12 (permalink) Old Apr 5th, 08, 10:55 AM
I don't get this at all b/c I think my '67, 350SS engine had an 8" damper on it!
Darn near the same one that was on my 409 "W" engine.
I do know it had THIN 6-banger/350 wide rubber mounts that I promptly ripped right in two so I drilled and countersunk one side and bolted them back together! Never had a problem after that!
And I broke turnbuckles and straps back then...
That's how my top rad hose got cut, the MM's broke and my motor jumped up and the fan belt hit the top hose! I ended up putting a kitchen sink chrome pipe in it as a spacer, never cut it again and it's still in my trunk now after ALL these years!!
pdq67
post #8 of 12 (permalink) Old Apr 5th, 08, 02:04 PM
Paul, The SS-350's and the 302's had a special 8" balancer. This is why the 350/302's had different frame and engine mounts then the 327's. - Tom
TJS69 is offline
post #9 of 12 (permalink) Old Apr 6th, 08, 11:43 AM
Charlie
Tom, you said there was a reason they switched to an 8" balancer. Why is that? What is the benefit to running an 8" balancer? Thanks.
67CamaroRS/SS is offline
post #10 of 12 (permalink) Old Apr 7th, 08, 07:21 PM
JohnZ's Avatar
The inertia ring and polymer isolator on the "balancer" (actually a "damper" - it doesn't "balance" anything except on 454's and 400's) is designed to damp a specific range of torsional vibration at a given expected average operating rpm; higher rpm and stronger combustion pulses require different damper tuning than a standard grocery-getter.
JohnZ
CRG
JohnZ is offline
post #11 of 12 (permalink) Old Apr 8th, 08, 07:17 AM
Charlie
So how do I know if I should switch from my current 6 3/4" damper to an 8" damper?
post #12 of 12 (permalink) Old Apr 8th, 08, 09:12 AM
An 8" balancer is larger and can absorb more engine harmonics. If you would buy a high quality aftermarket balancer, I think you could go with a smaller diameter balancer. The engine you are getting comes with an 8" balancer... that is what the factory wanted to be used. Why would you want to switch to 1960's technology ?
TJS69 is offline
