Spark Plug Choice And Gap - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 4th, 08, 05:44 PM Thread Starter
DeAngelo
Question Spark Plug Choice And Gap
I bought some new spark plugs and would like someone's opinion on the gap needed. I have a 383 with Holley aluminum heads (Sytemax II), Lunati cam with 235 degree intake duration and 245 exhaust duration at .050 with a .490 and .500 lift. I have 1.6 roller rockers with a Holley Avenger 770 carb. I have an MSD HEI distibutor model # 8360 and a traditional cylindrical coil. The plugs are AC/Delco #5. It is a street car and never sees the track. Is this plug of the right temp and what gap is recommended? Thanks! DeAngelo
Deangelo66 is offline
post #2 of 11 (permalink) Old Apr 4th, 08, 06:38 PM
Re: Spark Plug Choice And Gap
Don't know what the seating to head seal looks like on a #5, I will guess this is an AC Rapidfire plug, taper seat? If its not, and its the newer type small plug with a gasket, I would use Autolite 3924. . You can get these at Autozone.
TC # 349
zdld17 is offline
post #3 of 11 (permalink) Old Apr 4th, 08, 07:33 PM
With an HEI, you'll want an 035 to 040 gap.
post #4 of 11 (permalink) Old Apr 4th, 08, 08:28 PM
Rusty
I would see what type of plug Holley reccomends. I know with my Brodix heads I had to find a plug with a 3/4" reach.
1991 Camaro RS, 355 cid, 10.5:1 CR, Scat crank, Speed Pro flat tops, Brodix IK180's. Comp XE268, 1.6 rockers, Perf RPM Air Gap, 650DP Quick Fuel, Hedman long tubes, BTO Level 2 700R4, 3.73 w/ posi.
wrsjr is offline
post #5 of 11 (permalink) Old Apr 4th, 08, 10:08 PM Thread Starter
DeAngelo
Thanks for the quick responses! Yes, it is a Rapid Fire Ac/Delco plug. I will check the Holley site and see what they say as well. Is this a decent spark plug? Thanks for all of your help! DeAngelo
post #6 of 11 (permalink) Old Apr 4th, 08, 10:21 PM
Mister here are some recommendations.
Gap your plugs 0.45 and get a spark plug that is one heat range colder FROM WHAT HOLLEY RECOMMENDS for a starting point and then read your plugs.
Keep in mind.
[Small gap more rpm's rougher idle.Wider gap better idle, more hp!]
You got a lot of duration for the street.I use NGK V GROOVE NON PLATINUM PLUGS is what i would recommend.Also i would try to have the car dynoed for the correct jetting in the carb.In Total timing 38* at 3000rpm.
To get the best driveability on the street.
Here is a nice article on it.
http://www.chevyhiperformance.com/te...est/index.html
collingdale is offline
post #7 of 11 (permalink) Old Apr 5th, 08, 07:50 AM
Patrick
Here is a place where you can cross reference your plugs for future help: http://www.clubplug.net/cross.html
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #8 of 11 (permalink) Old Apr 5th, 08, 09:20 AM Thread Starter
DeAngelo
Thanks, Paul and pat. I am going to put the plugs in as soon as it stops raining! Thx for all of your help. DeAngelo
post #9 of 11 (permalink) Old Apr 16th, 08, 06:32 PM Thread Starter
DeAngelo
FYI I chose the Autolite 3923. I wanted a little colder plug than the 3924. And I gapped it at .045 with initial timing at 12 degrees. It runs GREAT!! I had the AC Rapid fires but for some reason, I had to drop the timing to 6 degrees to keep it from bogging and knocking. Weird. Even after I dropped the timing to 6 degrees with the Rapid Fires, it ran pretty well but it broke up after 4 grand. That's when I took the Rapid Fires out and put in the Autolites. Now it is running like a top! Thanks, D
post #10 of 11 (permalink) Old Apr 16th, 08, 07:03 PM
Harley
wiskeesour's Avatar
I been playin with SBC's since I was a little bitty feller and I have always had luck with Autolites one way er 'nother. good choice.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #11 of 11 (permalink) Old Apr 16th, 08, 08:13 PM Thread Starter
DeAngelo
Thx, Wiskee. The Autolites have been VERY good to my SBC! D
