Dumb water pump question - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 4th, 08, 07:53 PM Thread Starter
Chris
This is going to sound pretty stupid, because it is, but how can I tell if I have a short or tall water pump on my engine? I want to replace the one that is on there now but I don't have a clue.
Buzz0 is offline
post #2 of 8 (permalink) Old Apr 4th, 08, 08:20 PM
Re: Dumb water pump question
What car, engine, year? Do you have one in place?, Short pump is just that, very little clearance between timing cover and back of pump, say early years to about 1968 or mid 68 or so, then the long water pump was on after that, Lots of space between back of pump and timing cover.
TC # 349
zdld17 is offline
post #3 of 8 (permalink) Old Apr 4th, 08, 08:57 PM
Dan
The short small block water pump is about 5-3/4" from the back of the pump to the pulley; the long pump about 7".
Stock '68 Camaro L48 M20 3:31 LeMans Blue Coupe, black deluxe int, console w/gauges
DanW is offline
post #4 of 8 (permalink) Old Apr 4th, 08, 10:15 PM Thread Starter
Chris
68 Camaro 210hp 327 car was built in April of 68
Buzz0 is offline
post #5 of 8 (permalink) Old Apr 4th, 08, 10:16 PM Thread Starter
Chris
Thanks Dan. I'll take some measurements in the morning. Am I correct in thinking that if I change from short to tall or vice versa then my ps pump and alternator will not line up with the pump pulley?
Buzz0 is offline
post #6 of 8 (permalink) Old Apr 4th, 08, 10:35 PM
bill
yes just that pulleys will be way off.also pump body is next to timing cover. if a cigarette goes in there a long style. if it dont short style
hereitis67 is offline
post #7 of 8 (permalink) Old Apr 4th, 08, 10:35 PM
You are correct. If you switch the waterpump length, you need to change ALL pulley's and ALL your accessory brackets. With a stock short water pump the alternater is on the driver's side. With a long water pump the alternater is on the passenger side.
TJS69 is offline
post #8 of 8 (permalink) Old Apr 5th, 08, 10:42 AM
And don't forget that Chevy made THREE, short, in-between and long!
In-between is for the 'Vette's if I remember right.
Please check Alan Groves site for more info if not mistaken.
pdq67
