Edlebrock Accelerator Pump? - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 5th, 08, 11:40 AM Thread Starter
I have a 1407 750 Edlebrock carb.
I have 3 Adjustment holes for the accelerator pump.
Which direction wold give me more intial fuel
the middle hole or the top hole?
thanks
68CamaroBLKSS is offline
post #2 of 6 (permalink) Old Apr 5th, 08, 11:45 AM
Re: Edlebrock Accelerator Pump?
hmmmm..... acelerator pumps can be "interesting"
They've all got a spring involved, ede, q-jet, holley, all of them.
The position of the rod on the lever (or the pump cam on a holley) controls how "quickly" the linkage pushes against the spring when the throttle is moved.
So the inner hole (which gives more leverage) will try to give a quicker stroke of the pump.
The actual fuel flow though, is a fight between the strength of the spring and the size of the orifice (pump squirter)
If you need more fuel, the best way is a larger squirter.
When I played with my ede, I found that the outer hole worked better cause it extended the shot thru when the secondaries were opening, ands helped cover a bog there.
post #3 of 6 (permalink) Old Apr 5th, 08, 11:56 AM
Charlie
On my Thunder Series 650, I have mine in the upper most hole. That is where I get the most fuel squirt. It was the same when I had the 1406 Performer Series. I believe all Edelbrocks are the same as far as the accel pump lever is concerned.
67CamaroRS/SS is offline
post #4 of 6 (permalink) Old Apr 5th, 08, 02:16 PM
Banned
Ron
Badbird's Avatar
A brand new, out of the box #1407 will have the rod in the top hole, for maximum fuel shot.
Badbird is offline
post #5 of 6 (permalink) Old Apr 5th, 08, 02:40 PM Thread Starter
great, thats what i needed to know.... I guess it was adjusted right.
How do i determine if its working correctly?
post #6 of 6 (permalink) Old Apr 5th, 08, 05:03 PM
Banned
Ron
Badbird's Avatar
That's a good one man!
Badbird is offline
