Drove it today...not impressed - Team Camaro Tech
post #1 of 32 (permalink) Old Apr 5th, 08, 06:51 PM Thread Starter
Craig
Brackneyc's Avatar
Well,. the new cam is in and I got to drive it today. It seems very unresponsive and sluggish. I put in a new Lunati Voodoo cam, had the heads done and added a new Carburetor. I ended up putting on the old carb because when you put it in drive, the engine would die. With the old Edelbrock, it will atleast stay running, but still has huge rpm drop when put in gear. I don't know if it the timing, the carb or just what it is. The tranny is leaking and the speedo stopped working. At idle it sounds amazing, and revs smoothly while in park. It seems ok driving, but a quick hit to the pedal, and it basically falls on its face.
Also, when I turn the lights on, both turn signals indicators glow green...never did that before. The car has basically sat for a full year, and I know stuff happens.
Any ideas for the lights or the motor? I'm taking it in to have the transmission looked at. I hope I don't have to have someone else tune it for me, but I may end up doing that too.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Brackneyc is offline
post #2 of 32 (permalink) Old Apr 5th, 08, 06:57 PM
Re: Drove it today...not impressed
Quote
"Any ideas for the lights "
Could be either a bad ground or the flasher relay.Most common is the ground.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #3 of 32 (permalink) Old Apr 5th, 08, 07:26 PM
john
wagonman's Avatar
sounds like retarted timimg......
put a timing light on it and see where your at.
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #4 of 32 (permalink) Old Apr 5th, 08, 07:28 PM Thread Starter
Craig
Brackneyc's Avatar
Would that also have caused some backfiring through the carb? It did that a few times, but didn't do it the last few times I started it.
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
post #5 of 32 (permalink) Old Apr 5th, 08, 07:33 PM
Banned
Ron
Badbird's Avatar
Sounds retarded to me too!
Badbird is offline
post #6 of 32 (permalink) Old Apr 5th, 08, 07:48 PM
Craig, what are you working on? Motor, cam , carb etc?
TC # 349
zdld17 is offline
post #7 of 32 (permalink) Old Apr 5th, 08, 09:39 PM Thread Starter
Craig
Brackneyc's Avatar
350, Edelbrock 600 268 Lunatic cam
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
post #8 of 32 (permalink) Old Apr 5th, 08, 10:26 PM
You got a problem somewhere. What's the timing set at?
I have a 350, 650 dp, holley, 276 voodoo with RPM heads at 10:1 compression.
That combo gets it done.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is online now
post #9 of 32 (permalink) Old Apr 5th, 08, 10:28 PM
Lane
I'm no expert here but could you have blown the power valve in the first carb?
Joe
69' Camaro X44 Base Coupe - 1\4 - 12.79
383 Stroker\700R4\Vigilante\12 Bolt Eaton Posi 3:55
QA1; Hotchkis; Vintage Air; IROC Steering Box
Owned and operated for over 20 years....................
04' CTS-V - Daily Driver -
LS6, Headers, Cam, Corsa exhaust, Electric cutouts.
sixtynine is offline
post #10 of 32 (permalink) Old Apr 5th, 08, 11:09 PM Thread Starter
Craig
Brackneyc's Avatar
My understqnding is that the new Holleys have a check ball to prevent blown power valves. Any truth to this?
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
post #11 of 32 (permalink) Old Apr 5th, 08, 11:32 PM
6D9
Ron
Yep....gotta be timing. Set her somewhere between 16-18 initail and 34-36 total. Should run sweet. How much compression does your 350 have??
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #12 of 32 (permalink) Old Apr 6th, 08, 01:45 AM
Harley
wiskeesour's Avatar
Is it backfiring, or spitting gas up thru the carb?
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #13 of 32 (permalink) Old Apr 6th, 08, 01:51 AM
set the initial timing to about 18 degrees, and put the vacuum advance to full manifold vacuum.
then come back and tell us what it does.
you don't plan sincerity.
novaderrik is offline
post #14 of 32 (permalink) Old Apr 6th, 08, 05:55 AM
The guys got it.
Advance the timing some more.
Both signal indicators glowing with headlights on = bad ground to gauge cluster.
post #15 of 32 (permalink) Old Apr 6th, 08, 07:16 AM
Red face Re: Drove it today...not impressed
What keyway did you put the timing set at??
Maybe off 4 degrees one way or the other??
Know all about this..
pdq67
