no fire - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 5th, 08, 10:17 PM Thread Starter
no fire
I recently put in a petronix ignition conversion kit and coil. My 396 ran great for a couple of months. Then, depression set in. At first it would try to start while the starter was turning the die when the key relaxed to on. Now its not even trying to start. Got fuel. Got battery juice. Wires all connected. Timing was OK recently and the distributor is still on the mark. Caps on tight. Help!!
68fan is offline
post #2 of 5 (permalink) Old Apr 5th, 08, 10:29 PM
Re: no fire
It sounds like your ignition ground may not be good enough, or you new box went bad. Are you getting spark at the plug?
Travis1 is offline
post #3 of 5 (permalink) Old Apr 5th, 08, 10:35 PM Thread Starter
Re: no fire
I guess I could hook up my timing light to see if I'm getting spark to the plugs. When you say the "new box" might have gone bad, do you mean the coil? thanks
68fan is offline
post #4 of 5 (permalink) Old Apr 6th, 08, 02:11 PM Thread Starter
Re: no fire
Problem solved. Must have had faulty connection to coil. Reconnected and now runs like a top!
68fan is offline
post #5 of 5 (permalink) Old Apr 6th, 08, 08:50 PM
Re: no fire
There ya go. Glad you get it goin.
Travis1 is offline
