Lifters won't fit - Team Camaro Tech
post #1 of 12 (permalink) Old Apr 6th, 08, 01:34 PM Thread Starter
Jon
Lifters won't fit
This is really weird, can't get my lifters to fit. Even tried an old one just to see if it would fit, and it was too big also. Rebuilt several small blocks and don't remember ever having a problem getting new lifters to slip in. Any ideas?
joncam67 is offline
post #2 of 12 (permalink) Old Apr 6th, 08, 01:41 PM
Harley
wiskeesour's Avatar
Re: Lifters won't fit
mic'em at .842
They should fit. Most gms are 842 I think...scratch scratch...
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 12 (permalink) Old Apr 6th, 08, 01:45 PM
Ron
Yes .842" are the STD Chev lifter Dia. I suspect your lifter bores are either very dirty or corroded. Use Laqcuer thinner on say a 12 gauge shot gun cleaner wad and spin it in the bores with a hand drill. Sometimes a Small Brake Hone will freshen up the Bores providing they are not too bad.
This was my 70 1/2 Z28
Z15CAM is offline
post #4 of 12 (permalink) Old Apr 6th, 08, 06:09 PM
Bill
Jon,
How was your block cleaned ? We have found that when we shot blast them, even though it makes them look like new, it does "roll" over a little material at the tops of the lifter bores. We have a small dingle hone at the honing machine and run it a couple of strokes on every block we do, that solves the problem.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 12 (permalink) Old Apr 7th, 08, 02:07 PM Thread Starter
Jon
thanks for the input. block was cleaned at the machine shop, and I thought they just hot tanked it. engine sat in my garaage for about a year in an engine bag with oil on it, so it isn't corroded. got the lifters to go in by tapping them lightly with a small hammer, and then got them back out (rag and pliers) after degreeing the cam.
joncam67 is offline
post #6 of 12 (permalink) Old Apr 7th, 08, 02:26 PM
Sure hate to see lifter stick when running, as mentioned, a small brake hone or ball hone will clean this edge up. Sticking may even keep lifter from spinning, thus , burnt lobe.
TC # 349
zdld17 is offline
post #7 of 12 (permalink) Old Apr 7th, 08, 04:39 PM
I ALWAYS finger my lifter bores w/ oil and then spin each lifter in it's bore to make DARN sure they ALL spin!
And watch fingering them down in there b/c the bottom machine corners are sharp and will nick a finger in a heartbeat!
pdq67
post #8 of 12 (permalink) Old Apr 8th, 08, 01:12 PM
Ron
FOR SURE.
I've taken a chunk off my fingers and added some of my rare RH Negative to ensure the cam lobes get the best chance to survive that critical break in - LOL
Z15CAM is offline
post #9 of 12 (permalink) Old Apr 8th, 08, 03:02 PM
Originally Posted by Z15CAM View Post
FOR SURE.
LOL...I can see how that might work.
dnult is offline
post #10 of 12 (permalink) Old Apr 8th, 08, 11:38 PM
That doesn't seem like the smartest thing to do.
SepsiS is offline
post #11 of 12 (permalink) Old Apr 9th, 08, 05:37 AM
Gary
You should NEVER have to use force to get 'em in the bores. Have the machine shop check the lifters and bores before you go any further - sounds like a disaster waiting to happen unless it's remedied now.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #12 of 12 (permalink) Old Apr 9th, 08, 05:00 PM
DITTO Gary here!!
pdq67
