just curious 406+++ - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 6th, 08, 03:09 PM Thread Starter
just curious 406+++
I seen a couple of builds using a 406 short block with vortec heads and rpm intake making about 430 horse and 525ft/lb of torque. I already have the heads and intake etc...what would happen if you put the same combo on a bigger short block(say a 434) How much horse are the heads good for? My ultimate plan would be to buy a short block, make good horse and torque numbers, and be able to upgrade heads, intake, etc... later on. thanks
68 camaro, 350 vortec heads, rpm air gap, lunati voodoo cam, coated headers, th350, 100 shot, 3.73, eaton posi.
justincat is offline
post #2 of 8 (permalink) Old Apr 6th, 08, 04:14 PM
Re: just curious 406+++
The Vortecs have their limits and I think if you're looking for torque then they're the ticket.
230cc head would be best on a 434 IMO... but a smaller head will still work.
68 Camaro~LSx ~all motor
post #3 of 8 (permalink) Old Apr 6th, 08, 04:32 PM
Michael Gekko
The Vortechs aren't going to flow enough for a big difference in HP between a 406 and a 434. You will see more torque with that big arm in there though.
If you are putting a new rotating assembly in the block then i would stroke it...there usually isn't much difference in parts between 406 and 421-427-434. just some clearancing and an oil pan kinda stuff
Eleanor's Nemesis is offline
post #4 of 8 (permalink) Old Apr 6th, 08, 04:54 PM Thread Starter
Well I just seen you could buy 406-434 short blocks. I already have everything set up for sb, so I would be pretty much just putting a new short block. Do you build a 434 pretty much the same as some of the 406 builds you see as far as cam etc...any 434 builds to look at somewhere? I see tons of 406 builds in chevy hi performance etc.. but not much on 434s
post #5 of 8 (permalink) Old Apr 6th, 08, 10:15 PM
Michael Gekko
You will have to check to make sure the cam isn't going to get hit by a rod, if so you have to use a small base circle cam. The block will have to be clearanced, and a kicked out oil pan will have to be used.
I recommend using a good piston-JE, SSRP, Ross, someone like that. I would imagine the side load on the piston is pretty steep and piston speed is certainly higher than a 350.
Call a cam company and see what they recommend. I am using DART Iron Eagle 215's that have been touched up a little and a Pete jackson gear drive. Flat tappet solid lifter cam.
Intake is a Victor Jr with 850 DP carb. Will get 600 HP on pump gas (or very close). 1 and 3/4 primaries on the headers.3 inch exhaust.
the car of course has to be built to use the pwer the engine is making effectively.....all steel 68 with cal tracs, 4.10 gear, 3500 stall converter (3800 really) in a THM 350
I am using a SCAT rotating assembly with JE pistons in mine. Short block is done.
If you are going to spray it something stronger in the bottom end will be a wise investment to get a callies crank or similar.....they are $$$.
sure, nothing wrong with building a good short block and upgrading heads and cams and induction/exhaust later.
post #6 of 8 (permalink) Old Apr 7th, 08, 06:33 AM
Vortec heads will really wake up a stocker early 350. They will help on a 400. On a 434 I think you will be back to the equivalent of a stock head on a 350. Not saying the power numbers of a 350, but the efficiency numbers.
Think about how big the valves are on a BBC.
A larger bore will make a valve able to flow more due to unshrouding.
A smaller bore will be more efficient than a bigger bore if the same valve size is used. So in order to make up for the lower efficiency, you need to size up the heads or else throwing more cubes at it won't have as much effect. Look at some of the SBFords made. They were 4" bore, short stroke, and a stupid small valve stock. Look what happens to them when you put a 1.90 or 2.02/1.60. They wake up real fast. Now imagine you put those same 2.02 heads on a 460. Do you think people would still pay $1000+ for the minimal efficiency increase here? Not unless they are ricers...
lluciano77 is offline
post #7 of 8 (permalink) Old Apr 7th, 08, 12:05 PM
SY1
If you are planning on building anything with a stroke longer than 3,80 you will want to consider strongly an aftermarket block. Once you go beyond that stroke (412-415 cid depending on bore) you begin to start running into clearance issues. Also you'll benefit from the thicker cylinder walls of an aftermarket block as the thrust sides of the cylinders begin to get loaded pretty well as the stroke goes up and you've probably already bored it .030. You can help this cause by running longer rods, but the ring package begins to get pretty tight, 1" or less on the real long strokes which begins to create other issues. I have enough into my stock 400 block now that I really should've just bought a Dart aftermarket block.
There's a reason you see so many 406 builds, they are easy to do. The grief and cost versus the payoff may not be worth it to you to go bigger, unless you really plan on spending a lot of time checking clearances and matching components. Otherwise you won't gain a lot as others have already said. Vortecs wouldn't be a consideration for me on a 400 or larger motor. They'll work, but they won't be optimal IMO. It's a matter of what you can live with.
"..............what, and get out of aviation??"
SY1 is offline
post #8 of 8 (permalink) Old Apr 7th, 08, 04:51 PM Thread Starter
thanks fellas
