95 LT1 Question - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 7th, 08, 02:59 AM Thread Starter
95 LT1 Question
I have a question about where the balancer hub and crank shaft meet. Is there suppose to be a crank key on the shaft? There was not one when I pulled the hub off, but inside the hub shows signs of there being one. I know on other small blocks there is, but this is my first LT and not quit sure. This is in a 95 Camaro Z28. Any input on this is greatly appreciated. Thanks, Eric
95_camaro-man is offline
post #2 of 2 (permalink) Old Apr 7th, 08, 10:28 AM
Ron
Re: 95 LT1 Question
Eric, No there isn't, You put the engine at TDC #1 and there is a mark on the hub that points a 12:00 if I remeber correctly. Ron
ROPO355 is offline
