Lifting an engine for a freeze plug replacement - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 7th, 08, 08:15 AM Thread Starter
frank
Frankrentef's Avatar
Thumbs up Lifting an engine for a freeze plug replacement
Experience, wisdom and guidance is needed....
I've been trying to replace a freeze plug (by the passenger engine mount) and continually find myself unable to reach the bolt that holds the mount to the block (front side of the engine.) It seems I'm unable to get a wrench or ratchet on the bolt due to space.
So, I'm going to attempt to lift the entire engine up a couple of inches using a hoist. I'm scared to lift from the bottom of the oil pan as half of the stories I hear result in the oil pan being crushed (and half of the stories say it works fine.)
My question is two fold.
Will I hurt any thing (transmission, etc.) by lifting the engine up a couple of inches (unbolting from both sides.) And / or where is best to attached the lift chains? I'm trying not to unbolt the exhaust manifold.
ANY advice is welcome.
THNX
67 Camaro RS - 383 Stroker
Factory A/C - Muncie 4 speed
Frankrentef is offline
post #2 of 6 (permalink) Old Apr 7th, 08, 10:15 AM
Re: Lifting an engine for a freeze plug replacement
You might want to keep an eye on the distributor cap, not literally though, so it doesn't get broke. Other than that you should be able to raise it enough to remove the motor mounts.
deerhunter is offline
post #3 of 6 (permalink) Old Apr 7th, 08, 11:46 AM
Ray
Hello if you what a temp fix try one of these a Motormite Expansion Plug They do work. You can get it in without removing the Engine.
http://www.partsamerica.com/ProductD...pe=740&PTSet=A
Later Ray
rays68camaro is offline
post #4 of 6 (permalink) Old Apr 7th, 08, 11:47 AM
Agree here, dist cap, maybe accel linkage, heater core nipple, fan to fan shroud clearnace, You can lift motor from oil pan but I would place a 2x6 or 2 x 8" block of wood flat on the bottom where the outer edges of the block fit against the pan, ie , equal weight distribution. May even have to disconned headers or exhaust pipes.
TC # 349
zdld17 is offline
post #5 of 6 (permalink) Old Apr 7th, 08, 01:24 PM Thread Starter
frank
THNX all,
On the freeze plug from Advanced Auto... I picked up one there like that but not quite the same... I'll print out the link and take it by the store.
THNX
post #6 of 6 (permalink) Old Apr 7th, 08, 02:28 PM
1 5/8's brass deep cup, accept nothing else, use some Permatex on edges. Tap in with large socket that will fit the cup or if you have the fancy plug installer..
TC # 349
zdld17 is offline
