Having trouble running Engine Application Code - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 7th, 08, 10:31 AM Thread Starter
Post Having trouble running Engine Application Code
Engine Application Code is listed as V01O9TJZ (yes that o9 not 09) checked it three times! But lets pretend it is 09.
V- Flint Michigan
01- January
09- Ninth
TJZ- Unsearchable
This stamp is clearly visible and readable.
There is no mitake on TJZ.
Need to know for sure if it is a 350 or 305, and since the motor is already in the car the block VIN is a little hard to obtain at the moment.
Any help in this matter would be greatly appreciated!
Further note- 82 camaro berlinetta (obvoiusly not the original motor!)
johndoe75460 is offline
post #2 of 4 (permalink) Old Apr 7th, 08, 11:56 AM
Ron
Re: Having trouble running Engine Application Code
T= truck engine. Start in the truck books. Don't have them here or I would look for you.
rontoomanyprojects is offline
post #3 of 4 (permalink) Old Apr 7th, 08, 04:42 PM
"TJZ" = 1973, 155hp/350, Conv. Cab., 4-barrel, C/10 to 2500 P/U's.
pdq67
post #4 of 4 (permalink) Old Apr 8th, 08, 07:49 AM Thread Starter
Cool Re: Having trouble running Engine Application Code
pdq67
Hey, thanks alot! now that i think of it soun ds about right.
I think i was looking at a chevelle site. last three digits starting with c for car...and of course mine starting with t..... yeah im new to all this!
See I was worried it amy turn out to be a 305 because i have bought two oil dipsticks for the 350 block mount and niether of them would fit. The tube is slightly too big. So i found and old oilpan tube (which had a similar curve) and cut it to the same length and it fits fine only because the middle of the tube where i cut it from is smaller. The only thing i could think of was maybe the old one got stuck in there and was broke off, but there is no way the piece remaining in the block would stay perfectly round and would probably have a jagged edge sticking out. which mine doesnt have. I guess i will just have to put 8 quarts of oil in and let it settle and then put in the dipstick and get my dremel tool and engrave a new full line to ensure I get a good oil level reading. Id rather use an original dipstick. but for some reason thats not workin out for me.
Thanks again for your help, and if you have anymore ideas let me know!
