Help Engine Loping - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 8th, 08, 06:39 AM Thread Starter
Help Engine Loping
Ok heres the problem when i drive my 93 v6 5 speed, it starts to hesitate and jump then backfires and stalls, I have replaced the following
EGR Valve, Cam Sensor, Plugs, MAF, Throttle position Sensor, Plug Wires, Cleaned the Throttle body, checked 3 times for Vaccume leaks and found none. I bought a code reader but cannot retrieve the codes because the check engine light comes on but does not flash when the reader is in, so thats another issue. I am at my wits end here, I love my Camaro but I am losing patience can some one plese let me know if they have had this problem or if anyone has any ideas
Thank ytou in advance for your help
Ed
suldevan93 is offline
post #2 of 3 (permalink) Old Apr 8th, 08, 07:45 AM
Trevor
Re: Help Engine Loping
Have you checked fuel pressure?
osin68 is offline
post #3 of 3 (permalink) Old Apr 8th, 08, 09:40 AM Thread Starter
Fuel pressure is good, changed fuel filter also
Im at a loss here
