Ground Cranks - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 9th, 08, 02:02 PM Thread Starter
Ground Cranks
Hey guys,
I have 6223 crank that has been ground .020/.020
What does this mean for an SHP application in terms of strength? I have read that this crank was Tuftrided and grinding the crank removes this coating. Is this a big deal, or am I still safe using this crank.
Hate to need to get a new crank.
thanks,
Joel
Joel 67 is offline
post #2 of 5 (permalink) Old Apr 9th, 08, 04:26 PM
Vintage 68's Avatar
Thumbs up Re: Ground Cranks
I have used plenty of 10/10 & 20/20 cranks in street HP engines that have lived long and very happy lives
The coating is not that big a deal in the big picture of things.
These forged cranks were very stout and as long as the crank has been properly machined and prepared it should be just fine unless you are planning on lots of flogging.
If you just aquired it and are unsure of it true past, I would recommend you have it carefully checked and polished by a reputable crank-shop if this hasn't been done. They will be able to give you a better assurance it will fit your needs.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 5 (permalink) Old Apr 10th, 08, 08:09 AM
Re: Ground Cranks
If you are cutting a crank for what ever reason, this is the time to do some oil hole chamferring ( sp) . Useage of soft bearing will help.
TC # 349
zdld17 is offline
post #4 of 5 (permalink) Old Apr 10th, 08, 12:14 PM
Re: Ground Cranks
I wold not worry about cutting a crank down. Pro stock often runs a very small rod journal and those are put to some serious power.
tqueen is offline
post #5 of 5 (permalink) Old Apr 10th, 08, 12:27 PM
Patrick
Re: Ground Cranks
My crank is cut: rods .040 and mains .030 and see's 7000 plus rpm daily! Engine is in sig.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
