Starter grinding, need advice - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 9th, 08, 08:43 PM Thread Starter
I'm looking for advice. I changed my oil today on my 68 Camaro. I'm getting it ready for spring time. I used 1 qaurt of the lucas oil stabilizer along with 4 qaurts of Castrol conventional oil. I went to start the engine to get the oil pressure up and the starter began to make an awful grinding sound as I tried to turn the engine over. I turned the key off waited a minute and attempted to start the engine again. The started made another grinding sound. I turned the key off off again, waited another minute and attempted to start the engine one more time. The engine fired right up and ran great. The oil pressure is good. I have never heard that grinding sound come from the starter. The engine is a 427 BB with 11:1 compression. The engine was rebuilt very recent before I got the car. I was told their are about 1500 to 2000 miles on the rebuilt engine. I have never used the Lucas oil stabilizer before. Is it possible that could be causing the problem? The lucas oil stabilizer is a very thick oil product. Could that cause the engine to turn over very hard along with the high compression, maybe to much for the starter? Or could it be that the starter is going bad. I have no idea if the starter was replaced when the engine was rebuilt. I think that the starter is an OEM style starter. I know that the starter is not a high performance starter. I'm not sure if I should drain the oil and change it again only using conventional oil and not use the Lucas oil stabilizer or try something to test the starter. Any help would be greatly appreciated. Thanks.
mike65red is offline
post #2 of 6 (permalink) Old Apr 9th, 08, 08:48 PM
Lane
Re: Starter grinding, need advice
I'm sure others will chime in but my first thought is stuck bendix or starter needs adjustment.
69' Camaro X44 Base Coupe - 1\4 - 12.79
383 Stroker\700R4\Vigilante\12 Bolt Eaton Posi 3:55
QA1; Hotchkis; Vintage Air; IROC Steering Box
Owned and operated for over 20 years....................
04' CTS-V - Daily Driver -
LS6, Headers, Cam, Corsa exhaust, Electric cutouts.
sixtynine is offline
post #3 of 6 (permalink) Old Apr 10th, 08, 07:01 PM
Red face Re: Starter grinding, need advice
sounds like the starter may not be shimmed properly. check that out first, its easy enough to fix
L7869 is offline
post #4 of 6 (permalink) Old Apr 10th, 08, 07:58 PM
If it sat for the winter I would guess along with sixtynine that the drive stuck on the shaft.
Sounds like you cured the problem after a few trys.
Rob.Canada is offline
post #5 of 6 (permalink) Old Apr 10th, 08, 08:13 PM
If you are capable and you think its in the starter shimming, I would get under the car and take the cover off of the flywheel , disconnect batt power , take the starter off and clean it up or have it tested. You may be also able as someone suggested, try shimming the starter but if you have never done this and are not mechanically inclined to understand what is going on, best find someone that does. You can mess up a starter ring gear real quick.
TC # 349
zdld17 is offline
post #6 of 6 (permalink) Old Apr 11th, 08, 05:30 PM Thread Starter
Thanks everyone. The car seems to be starting fine now. I will continue to monitor this. thanks for the help.Mike
