Votec heads and dome pistons - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 9th, 08, 09:00 PM Thread Starter
Well I just pulled my heads off of my 327 and to my surprise I have dome pistons. They are small domes with reliefs cut for the valves. I was planning on using Vortec heads but I am not sure they will work with these pistons. I'm also concerned this will put my CR to high.
737IP is offline
post #2 of 3 (permalink) Old Apr 10th, 08, 06:10 AM
Patrick
Re: Votec heads and dome pistons
It will deff pot your CR very high. Prob have to run race gas. It's always a good idea to check piston to valve clearance also especially with dome pistons.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #3 of 3 (permalink) Old Apr 10th, 08, 07:48 AM
mbrekke's Avatar
It depends on the dome, but I'm guessing it's not going to work. Check out the pics:
http://www.customclassictrucks.com/t.../photo_06.html
The 'point' on the quench surface coming down between the valves may interfere with the piston dome in a true Vortec head.
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
