What does it mean to float pistons to rods? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 10th, 08, 09:24 PM Thread Starter
Drew
The title pretty much says it all. I know it is probably a stupid question but what does it mean when guys say that their pistons and rods have been floated?
Drew1485 is offline
post #2 of 5 (permalink) Old Apr 10th, 08, 10:20 PM
Re: What does it mean to float pistons to rods?
A floating piston is one that is bolted to the rod, or there is pressed in pistons. I guess it could also mean it is broke in the cylinder and floating around in there if someone is refering to a damaged engine
68 camaro, 350 vortec heads, rpm air gap, lunati voodoo cam, coated headers, th350, 100 shot, 3.73, eaton posi.
justincat is offline
post #3 of 5 (permalink) Old Apr 10th, 08, 10:31 PM
Keith
The round pin that connects the connecting rod to the piston can be hooked into the rod in basically two ways. 1. The most popular way is to press the pin into the hole in the rod using a press. The pin is locked into the rod by the tight fit and does not turn in the rod. The pin slides into the holes in the piston and allows the piston to rock back and forth and slide on the pin. 2. The hole in the connecting rod is drilled bigger and a bushing is pressed into the rod. The hole in the bushing allows the pin to turn because the bushing hole is a little bigger than the pin. The pin slides in the piston the same way as pressed pins. Way number 2 is called a "floating" pin system because the pin can move in the rod and the piston. The pin must be kept from sliding out of the piston by clips so it won't rub the cylinder wall.
Keith
Kamcoman is offline
post #4 of 5 (permalink) Old Apr 10th, 08, 10:38 PM
Jerry
It's pretty simple. "Normal" piston pins are pressed through the piston into the small end of the rod and can't rotate. A "floated" pin can spin freely in the small end of the rod. Since the pin is now free to move side to side, the pin must be retained in piston to keep it from hitting the cylinder walls, for example, with snap rings.
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
69 z11 is offline
post #5 of 5 (permalink) Old Apr 11th, 08, 05:29 AM Thread Starter
Drew
Thanks for the info guys!
Drew1485 is offline
