Fuel pump size - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 11th, 08, 12:55 AM Thread Starter
Fuel pump size
Ok, may be silly ?. If I'm running a 327 (approx 375 hp, 600 Holley)...can I run most standard fuel pumps or do I need to start researching. I see there are pumps for the really big'ns but didn't know how precise I needed to be. Most I find just say they are for a SBC. Thanks.
Koennicke68 is offline
post #2 of 3 (permalink) Old Apr 11th, 08, 06:48 AM
Charlie
Re: Fuel pump size
You will be fine using an Edelbrock Performer pump(6psi-110GPH) or one like it. They say you usually don't require a regulator, but I found that my engine runs more consistantly with one. Regulated at 5psi.
http://store.summitracing.com/partde...5&autoview=sku
67CamaroRS/SS is offline
post #3 of 3 (permalink) Old Apr 11th, 08, 09:38 AM
Banned
Rob
satz28's Avatar
Re: Fuel pump size
I think a stock GM fuel pump would work fine.
satz28 is offline
