427 crank - Team Camaro Tech
post #1 of 12 (permalink) Old Apr 11th, 08, 05:35 AM Thread Starter
Matt
Blade's Avatar
Send a message via AIM to Blade
427 crank
For those who know alot about motor. Can you put a 427 crank into a 454 block?
Got to give the PEOPLE what they want!
Look....if you wanna be the best then you gotta take out the best!
1967 Prostreet Camaro
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
Blade is offline
post #2 of 12 (permalink) Old Apr 11th, 08, 05:53 AM
Gary
Re: 427 crank
Yep, you'll have a 427. 427 and 454 blocks are both 4.250 standard bore, the crank is the difference, 3.766" stroke for a 427 and 4.0" stroke for the 454.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #3 of 12 (permalink) Old Apr 11th, 08, 08:55 AM Thread Starter
Matt
Blade's Avatar
Re: 427 crank
ok then bored .30 over would be a 431?
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
Blade is offline
post #4 of 12 (permalink) Old Apr 11th, 08, 10:58 AM
Re: 427 crank
Yes, that is correct.
67funcar is offline
post #5 of 12 (permalink) Old Apr 11th, 08, 12:34 PM Thread Starter
Matt
Blade's Avatar
Re: 427 crank
thank you!
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
Blade is offline
post #6 of 12 (permalink) Old Apr 11th, 08, 12:58 PM
Ron
Re: 427 crank
The 427 like the 302 can be built up from the GM inventory basket. Just put a 396 crank into a 454 Block and run the appropriate piston. I personally like the 427. The short stroke sure winds it up and you do not have to put out additional expenses for external balancing. The 427 was known as the engine that put out the biggest bang for the buck.
This was my 70 1/2 Z28
Z15CAM is offline
post #7 of 12 (permalink) Old Apr 11th, 08, 04:47 PM
george
Re: 427 crank
I do not think you meant a 300 thou overbore.
FWIW..433 cid.
Bore x bore x stroke x .7854 x # of cyls.
.030 over =4.280
stroke is 3.76.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #8 of 12 (permalink) Old Apr 11th, 08, 06:24 PM
Skip
Skeeter55's Avatar
Re: 427 crank
If you put a 396 crank in a 454 block then what do you get?
Would still be called a 427 or 396?
Thanks Skeeter
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #9 of 12 (permalink) Old Apr 11th, 08, 06:55 PM
Ron
Re: 427 crank
Skip: Aren't we discussing 427"s here - LOL
Z15CAM is offline
post #10 of 12 (permalink) Old Apr 11th, 08, 08:05 PM
Skip
Skeeter55's Avatar
Re: 427 crank
I understand that we are discussing the 427 crank. But Ive ben told that a 396 crank in a 454 block will still give you a 427 Cubic inch.
Don't kill me for the lack of knowledge I'm just asking a question, that you have an honest answer to. So help me out because its all about LOL
Nice pictures by the way....
post #11 of 12 (permalink) Old Apr 11th, 08, 08:11 PM
Skip
Skeeter55's Avatar
Re: 427 crank
Can you explain to me the deference between using a 396 vrs 427 crank in a 454 block..
post #12 of 12 (permalink) Old Apr 11th, 08, 10:00 PM
Ron
Re: 427 crank
The 427 crank and the 396 crank are the same thing and can be used in either the 396 or 454 block which is the same as the 427 block. If you put a 396(427) (3.75 Stroke) Crank into the 4.25" bore of either a 427 or 454 Block (which are the same thing) you end up with a 427.
Z15CAM is offline
